About to do some maintenance work on the car, thought I would post the part numbers in case anyone ever needs them (all Nissan part numbers):
*A/C Belt: 11920-30R10
*Power Steer Belt: 11950-59S02
*Fan Belt: 11920-42L01
*Bottom radiator hose: 21503-72L00
*Top radiator hose: 21501-05U00
*Fuel filter: 16400-53J10
*Oil filter: 15208-H8911AU
*Wiper blade (500mm): 28895-79903
*Wiper blade (475mm): 28895-89902
Hope that helps
https://www.sau.com.au/forums/topic/57514-r32-gtr-part-numbers-for-reference/
Australian built r31s
10 dash lights cluster.. P/shift etc. = 25020-j7003
4 dash lights ( right side of the dash) Oil,Fuel etc = 25025-j7001
Series 3 front bumper support = 62030-91S30
Thermostat - 21200-42L05
Ryco oil filter - Part number Z145A
Ryco air filter - Part number A360
Ryco fuel filter - Part number Z202
Import - GTS, GTSX etc
Import rear window defog dash switch = 25350- 51S06
RB20DET AFM - 22680-02U00
RB26DETT AFM - 22680-05U00
RB26DETT FUEL FILTER - AY505NS004
RB26DETT SPARK PLUGS - 2240158S16
RB26DETT OIL FILTER - 15208H8911
R33 GTST RB25DET
FUEL FILTER - 1640041B05
ROCKER GASKET COVER - 1327058S01
1327058S11
TURBO INLET GASKET - 144154P200
SPARK PLUGS - 224011P116
EXHAUST MANIFOLD GASKET - 1403621U00
EXHAUST STUD - 14064N4200
guys;
thanks for the info. just wondering if these are the numbers on the part or numbers off the Nissan software? i was recently at Lennock Nissan in Canb and queried the number on a package as it didn't match up with the number on the microfiche diagram printout they gave me. their response was 'oh don't worry about trying to match the numbers because they don't' go figure...
i thought i'd ask seeing that they are mercenary about parts ie ex Japan stuff can't be returned and they ask you to ID the part on the printout so the onus is on you to get it right...again, go figure.
thanks
Good stuff fellas!
Part numbers are great but if they were posted in a permanent section it would be better!
http://www.sau.com.au/forums/showthread.php?t=56447
What do you reckon? :P
  • 4 months later...
