Erm, and this is a performance mod how? :D
I'm looking at a photo of a series 1 and 2 front end right now, and it looks like only the inner top corners are different. You'd probably want to check and measure them physically before buying them though.
I don't think the plastic is any different between series 1 and 2. You probably just need to give yours a bit of cut back polish. My series 1 headlights are very clear aside from a couple of tiny spots of dullness. I'll polish these out one day.
Have a look at the attached pic of my front end, you can see the right headlight is reflecting lots because it's in the light, and the left headlight you can barely see at all because it's in the dark and almost perfectly clear. The clarity of the headlights was one of the first things that struck me about this car.
Personally I think the rounded series 1 corners look better than the series 2, but that's just me.
Originally posted by equinoz
i think i have to take them off, undo the plastic cover and polish it from the inside.
plz tell us how u do this... i took out the whole headlight out, but it just seems like its one-piece , ie u can't take the cover off... most prolli i am wrong , so teach me how to take off the plastic cover... thanx!
Before you pull your headlights apart to polish the inside.... ask yourself this question....
If I cant pull then apart, and they are sealed, what could have possibly happened so that I need to poiish the inside???
Answer: nothing, the inside is fine
I also thought it was inside, and I too tried to pull them apart...
But then I read a thread on here or SDU ages ago about giving them a good cut and polish, and it worked!
Mine were VERY badly scratched on the inside corners, and looked horrible. I used industrial strength cutting compound (no polish) a couple of times to get the plastic flat (and I scrubbed the crap out of them too). Then I gave them a cut and polish a few times, and now they are crystal clear.
As far as I know those covers are sealed, and nothings gets in, nor out, so trying to pull apart to polish the inside doesn't seem very logical to me.
Give it a try first.... you have nothing to loose. Just make sure you let the stuff dry properly out of the sun, and then scrub the crap out of them. If they are really bad, use a buff pad on a drill or grinder to buff them. That should do the trick!
Thats a really good point, but i could swear it looks as if some liquid has dribbled down the INSIDE of the lens. Mine arent scratched or even foggy, just has what looks like a water mark or something that you cant clean off from the outside.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
