  • Replies 41
There's a bloke called Phat32 who wrote into the group buys section who says he can get them for $325.
There hasn't been many reponses though - don't think many people want to go as big as an 044.
I thought you could mount a 044 internally - have read on a few of the forums here about blokes mounting them in tank - looks like it's a bit of a hassle as they're pretty big but can be done???
Anyway - if anyone here has got any practical experience in fitting one of these please enlighten us!
Cheers
edit:
Just did a search and yes, quite a lot of people have mounted 044's in tank.
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1110387
I can get them to you for $310 each. Dunno how I'd go asking for a group buy, but I can't see the problem. Takes like three days to get them in. I have fitted the 040 in tank with no probs. Takes like half an hour once you pop the boot. I will also do installs for $50 if anyone is interested.
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1110832
and before anyone starts asking questions...these pumps retail for $525.
and it would cost you around $80-$100 to get them installed(unless of course you do it yourself).
I am also a mechanic in case anyone was worried.
I have done several of these pump installs with no come backs.
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1110847
Gidday,
Surely we can get 10 skyliners in the Brissy area to get these pumps.
I know what you mean by postage etc - it'd be a lot easier if everyone could just pick up and pay - no stuffing around with banking/postage.
Cheers!
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1111063
won't make any difference unless your existing one is rooted..
About all I noticed was a tiny bit better throttle response, although this could have been my imagination.
installed another pump literally an hour ago.. although that one was a walbro which is tiny. Its an easy process (even easier in R32 as well!)
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1111653
Are the walbro units any good??
:D
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1111676
Well I'd actually go Bosch.. unless you really want to save money to spend on other things (like me). Walbro is fine for 250rwkw or so apparently. You hear conflicting reports though on how good they are. At $180 or whatever I paid, worth trying for a while.
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1111901
From another forum.. there were some walbros for $160. I just bought one for 165 from someone I knew in up in brissy. :D
https://www.sau.com.au/forums/topic/57542-bosch-fuel-pumps/#findComment-1113108
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
