lucky dip wreckers it is..
Unless you did want to wait until about February when I am pulling my rb20det out.. could see it running, driving around, etc. Least you would know it would be pretty decent condition (well I think it is, haven't really had a chance to check all the compression, etc yet)
thanks for the offer predator, how many Ks on it and do you give it a hiding? ill see what happens.
riverside, i would never have thought they would deal with import motors, ill give em a ring but i doubt they could help me. Waggotts have a reco service too might try them.
Repco do reco import engines, they are put together by www.hmgem.com.au
yes they cost a bit more but they are essentially new engines, as they do this.....
"Every engine is completely stripped and chemically cleaned. All old pistons, rings, bearings, valves etc. are scrapped. Every block is bored and honed. Every crankshaft is reground on all journals. Every camshaft is reprofiled and every cylinder head completely machined.
Remachined parts are again inspected and are passed on to the assembly area where all new parts are ready to match with the newly machined components
which are....
Pistons
Ring
Main Big End Bearings
Cam Bearings
Timing Chain or Gears
Tensioners and Guides
Inlet & Exhaust Valves
Welsh Plugs
Oil Pump Valves
Oil Pump Springs
Seals
Gaskets
Gallery Plugs"
and they offer a 3 year unlimited kilometers Australia wide guarantee
Man I should work for them
I need a new engine too, so I think at the end of the day I will go this way and then not have to worry about the "lucky dip" engine breaking in a months time.
Sigh so much money down the toilet
bad news lads.
Talked with repco today who talked to gem engines. apparently no one in the country(from that company) has ever rebuilt an rb20det. best they could offer is a strip and quote. said off the top of his head id be looking at about 4g. no exchange service available.
think i might give them a miss. i dont want them playing 'pioneers' with my motor.
i sent redlands an email ages ago-no reply
thanks for the offer predator, how many Ks on it and do you give it a hiding? ill see what happens. riverside, i would never have thought they would deal with import motors, ill give em a ring but i doubt they could help me. Waggotts have a reco service too might try them.
The speedo reads 90,000km but who knows.. well it hasn't actually been driven anywhere in australia yet, and its a completely stock auto.. It doesn't look like its had a hard life. RB20DET's are becoming harder to find apparently.
Pity about those gem-engine guys as it sounded promising.. guess they only focus on "mass market" motors as that is what everybody has.
Hey you could ask repco for a old Holden 186 motor from an XU1...
We just got my mates car on the dyno at redcliffe.... 186 Holden motor stock had done 280,000kms... Put an old Rb25 turbo on it with shaft play and all (was only gonna use it for making the exhaust and piping then replace when it was ready, but we couldnt wait) He produced 232rwkw at 14psi.... I was blown away and it sounded so good...
I will rebuild your engine for you if you like.
What is wrong with it to make you think it's on it's way out?
I just rebuilt mine with forged pistons for $3500 including new clutch and second hand head. All race bearings and competition gear.
I'll even do it at your house if you like. just to make things easier.
You'll have to be quick though as I am about to put together my mates 383 stroker.
Just after new year sometime.
Offer's there if you want it.
P.S. I can get a full price list of everything for you if you like.
Plus I don't mark up prices and I'll only charge labour.
  • 4 weeks later...
Funny you should say that, ive just rebuilt a 186 for a friend, cost us under 1g for completely fresh everything minus pistons and rods including a yellowterra head and chrome goodies, next is mounting the 1G Blower to it, should go quite well i think. We've been told it should make the same sort of power you mentioned and this entire conversion into my mates HR is costing less than 2g's includion the original purchase price of the engine, meybe we should all buy holdens??
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
