Hey people i just got my 89 R32 4 door auto.
Some questions.
1. It has this spoiler at the front that can come down when you are parked with the handbrake up????????????????? Whats this for????????
2. Power button?????????
3. Overdrive button??????????
4. Hold Button??????????
If anyone knows what all these are for please let me know.
https://www.sau.com.au/forums/topic/57614-my-r32/
Some questions.
2. should have power/snow button - power is meant 2 give u quicker gearchange..minimal difference tho & snow is 4 use in..snow in japan but in australia - when raining..will actually take off from standstill in 2nd gear 2 give more traction in poor road conditions.
3. overdrive is just 4th gear push in when over about 80kms..otherwise should leave alone when not on highway driving to have more acceleration.
Those other 2?? No idea sorry, maybe unique 2 4door or 32 model..mine is 33.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110560
hold button is not what the previous guy said ...but its basically for economcal driving ...it likes the reverse of the power button......
where the power button holds the gear longer and revs higher and changes quicker .....hold does the oppsite ...good for highway driving etc....
well this what is was like on the Nissan Pintara Ti auto ... i dont see why it would be any different
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110930
The spoiler comes down when you are parked??? Or there is a button to make it come down? Because normally it would come down at I think its about 100km or something, the button is to just keep it down. From memory anyway, a mates brother has basically the same car.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1111285
kkkkkkkkkkkkkkkkkkkkkkkkkkkk
why do you keep doing these gibberish posts in peoples threads?
back to topic
i have found using the overdrive button during normal driving might save you petrol... i fill up one day later when i leave it on for a week... I should properly test that one day.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1116499
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
