Hey people i just got my 89 R32 4 door auto.
Some questions.
1. It has this spoiler at the front that can come down when you are parked with the handbrake up????????????????? Whats this for????????
2. Power button?????????
3. Overdrive button??????????
4. Hold Button??????????
If anyone knows what all these are for please let me know.
https://www.sau.com.au/forums/topic/57614-my-r32/
Some questions.
2. should have power/snow button - power is meant 2 give u quicker gearchange..minimal difference tho & snow is 4 use in..snow in japan but in australia - when raining..will actually take off from standstill in 2nd gear 2 give more traction in poor road conditions.
3. overdrive is just 4th gear push in when over about 80kms..otherwise should leave alone when not on highway driving to have more acceleration.
Those other 2?? No idea sorry, maybe unique 2 4door or 32 model..mine is 33.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110560
hold button is not what the previous guy said ...but its basically for economcal driving ...it likes the reverse of the power button......
where the power button holds the gear longer and revs higher and changes quicker .....hold does the oppsite ...good for highway driving etc....
well this what is was like on the Nissan Pintara Ti auto ... i dont see why it would be any different
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110930
The spoiler comes down when you are parked??? Or there is a button to make it come down? Because normally it would come down at I think its about 100km or something, the button is to just keep it down. From memory anyway, a mates brother has basically the same car.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1111285
kkkkkkkkkkkkkkkkkkkkkkkkkkkk
why do you keep doing these gibberish posts in peoples threads?
back to topic
i have found using the overdrive button during normal driving might save you petrol... i fill up one day later when i leave it on for a week... I should properly test that one day.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1116499
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
