- Light-up badges (Nismo, TRD, Ralliart, TypeR Civic, Subaru)(BrandNew)(FullKit) = $40.00
- Seatbelt pads (Nismo, ralliart)(Black)(BrandNew) = MakeAnOffer
- Chrome gear knob (BrandNew)(Red gear pattern) = $25.00
- Intercooler Spray Kit (Complete)(BrandNew) = SOLD
- R33 GTST Fuel Pump (Great upgrade for S13/14. etc) = $70.00
- Guttered 2.5" cat = $20.00
- 2.5" piping (Long) = SOLD
- Mild Steel Muffler with chrome tip (Not loud at all)= SOLD
- TIMEX 2" Boost/Oil Temp(Smoked faced like DEFI ones)(Near New) = $50.00 (sell $120.00+ in shops each)
- AutoMeter Air/Fuel Ratio Gauge (52mm)(SilverFaced) = $75.00 ($120+ New) SOLD
- AutoGauge 2" Meters (Oil Temp/Boost/Volts/AirFuel)(BrandNew in Box) = $75.00 each
- 12" Custom Sub Box made for R33 boot specs (approx 35-40 litres) = SOLD
R33 GTST ITEMS
- Orange Side indicators = SOLD
- Stock Bonnet in Excellent condition = $350.00
- Stock front pipe with guttered cat = $50.00
- Tein Height adjustable coilovers (No Leaks)(No Pics as still on car) = SOLD (PendingPayment)
- Rear Key lock boot badge (Series 2) = SOLD
- Apexi Lowered Springs (Like New) = SOLD
- Stock shocks (GC)(FullSet) = $200.00
- R33 GTST Dash Cluster with under 100,000k = SOLD
I am also willing to swap/trade for:
- Huge intercooler
- IC Piping for R33 GTST
https://www.sau.com.au/forums/topic/57628-~lots2go~/
  • Replies 53
Hey guys,
I got my bits today, and would recomend buying from BlaKniTE. The parts were here very fast after payment......
Cheers mate.
https://www.sau.com.au/forums/topic/57628-~lots2go~/#findComment-1120370
- TIMEX 2" Boost Gauge/Oil Temp/Volts/Oil Pressure)(Smoked faced like DEFI ones)(BrandNew in Box) = $80.00 each (sell $120.00+ in shops each)
- AutoGauge 2" Meters (Oil Temp/Boost/RPM/Volts/AirFuel)(BrandNew in Box) = $75.00 each
G'day Blaknite - could you send me a few pics of these gauges. After a 2 inch boost gauge. [email protected]
Cheers
J
https://www.sau.com.au/forums/topic/57628-~lots2go~/#findComment-1128413
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
