- Light-up badges (Nismo, TRD, Ralliart, TypeR Civic, Subaru)(BrandNew)(FullKit) = $40.00
- Seatbelt pads (Nismo, ralliart)(Black)(BrandNew) = MakeAnOffer
- Chrome gear knob (BrandNew)(Red gear pattern) = $25.00
- Intercooler Spray Kit (Complete)(BrandNew) = SOLD
- R33 GTST Fuel Pump (Great upgrade for S13/14. etc) = $70.00
- Guttered 2.5" cat = $20.00
- 2.5" piping (Long) = SOLD
- Mild Steel Muffler with chrome tip (Not loud at all)= SOLD
- TIMEX 2" Boost/Oil Temp(Smoked faced like DEFI ones)(Near New) = $50.00 (sell $120.00+ in shops each)
- AutoMeter Air/Fuel Ratio Gauge (52mm)(SilverFaced) = $75.00 ($120+ New) SOLD
- AutoGauge 2" Meters (Oil Temp/Boost/Volts/AirFuel)(BrandNew in Box) = $75.00 each
- 12" Custom Sub Box made for R33 boot specs (approx 35-40 litres) = SOLD
R33 GTST ITEMS
- Orange Side indicators = SOLD
- Stock Bonnet in Excellent condition = $350.00
- Stock front pipe with guttered cat = $50.00
- Tein Height adjustable coilovers (No Leaks)(No Pics as still on car) = SOLD (PendingPayment)
- Rear Key lock boot badge (Series 2) = SOLD
- Apexi Lowered Springs (Like New) = SOLD
- Stock shocks (GC)(FullSet) = $200.00
- R33 GTST Dash Cluster with under 100,000k = SOLD
I am also willing to swap/trade for:
- Huge intercooler
- IC Piping for R33 GTST
https://www.sau.com.au/forums/topic/57628-~lots2go~/
  • Replies 53
Hey guys,
I got my bits today, and would recomend buying from BlaKniTE. The parts were here very fast after payment......
Cheers mate.
https://www.sau.com.au/forums/topic/57628-~lots2go~/#findComment-1120370
- TIMEX 2" Boost Gauge/Oil Temp/Volts/Oil Pressure)(Smoked faced like DEFI ones)(BrandNew in Box) = $80.00 each (sell $120.00+ in shops each)
- AutoGauge 2" Meters (Oil Temp/Boost/RPM/Volts/AirFuel)(BrandNew in Box) = $75.00 each
G'day Blaknite - could you send me a few pics of these gauges. After a 2 inch boost gauge. [email protected]
Cheers
J
https://www.sau.com.au/forums/topic/57628-~lots2go~/#findComment-1128413
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
