Maxx
Im going to buy one from you for my Series 1 Stagea.
I understand another Stagea owner with a Series 1 is currently using your CAI Box for a R34 Skyline, and apparently it fits all ok.
My query is: are the snorkel openings for a R34 and R33 on your CAI box the same?? ie, I have a R33 snorkel but would want to use your R34 CAI box..... is this possible??
Cheers, brendan
  • Replies 141
Maxx
Cheers, brendan
would also like an answer to the same question, for the er... same reasons. cheers.
  • 1 month later...
  • 1 month later...
im in sa - any chance of getting a template made for R32 GTS-t??? Can use my car!
Seems as though there is a lot of people interested!
Yeah I would buy one if they were made for an R32 aswell.
:happy:
  • 4 weeks later...
Hey the cai box with the clear lid looks awsome the only thing is will the box fit with the after market cooler piping. the stock snorkel had to be removed to allow the piping to fit so now i got a pod with a different cai. would still be interested in the box if if fit.
Also is there a hole in the bottom of the box to allow for my induction pipe, if not i'll cut one, just wondering.
I fitted mine to my R33 a few days ago, pretty decent looking, but it is not a straight fit to an r33. I had to chop off some bits to get it to sit low enough due to the bottom bit on the left (if standing in front of engine looking in) was hitting the stock cooler piping. not much but hey.
also one of the bolts on the lid was broken off on mine so the plexiglass or whatever it is has become loose at one corner.
It does leave a fairly decent hole under the pod where engine heated air can still get in, I think for max cooling it would need this hole sectioned off too - I might make a quick template and cut one out, looks like i could bolt it to the current screwshafts on the cai. anyone else done this?
  • 3 weeks later...
Are you still sellings these CAI boxes Maxx?
sure, but i am having my holiday at QLD (indy 300)
so send me a pm and i will reply u with all the detail once i go back to adelaide
  • 1 month later...
Hi Maxx....Do you still have any clear top CAI boxes and the Aluminium hood panel for R34 GTT ? Will be down to Adelaide next week... just wondering can i pick it up from you ? :nyaanyaa:
Hi Maxx....Do you still have any clear top CAI boxes and the Aluminium hood panel for R34 GTT ? Will be down to Adelaide next week... just wondering can i pick it up from you ? ;)
sure can :miner:
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
