hi all
i have a rb20det in my vl commy
im going to install a boost guage but i keep reading to install it up near the plenum?
wouldnt you install it closest to the turbo so i know what pressure the turbo is putting out and not what pressure the plenum is recieving after going round pipes and through the intercooler?
thanks
https://www.sau.com.au/forums/topic/57648-another-boost-guage-question/
hey mate, i would install it as close to the plenum as possible so you know exactly what boost the engine it getting after the boost drop has occurred in the plumbing, there wont be alot of boost drop though unles you have a leak.
i think it's just better to know what the motor is getting??
i guess it just comes down to personel preference in the end??
it wont really make alot of difference where you hook it up, just do it in the most convenient place, away from heat sources (exhaust) to protect the hose. try make the hose as short as possible so your guage respondes quicker.
If you are running a stock ceramic turbo, then it's probably safest to get the signal at the compressor. Then you can be safe in the knowledge that the exhaust wheel is not going to let go and de-glaze your bores.
If you have a steel exhaust wheel, then it's probably best to know exactly how much boost the engine is trying to ingest, and therefore pick up the signal at the plenum.
Jun's 1000hp R33 GTR has 2 boost gadges and 3 water temp gadges...
1 x boost at turbo
1 x boost at plenium
1 x temp inbetween cyl1-2
1 x temp inbetween cyl3-4
1 x temp inbetween cyl5-6
Thats the only way to have all the info i guess......!!! (Too much money)
Just put the adaptor that you get with the gauge onto the back of the plenum where the factory boost gauge gets its reading from. Its facing the firewall, the fitting should screw stright in.
Thats what I did when installing mine in the new car the other day.. The adapter screw fits into the standard plenum position perfectly (was a Speco gauge and std. kit it comes with). Unscrew the stock one, screw direct in the plenum. All done - nice plenum reading.
A 1000hp package requires that degree of monitoring given that you're sitting on a hand grenade and the gauges alone are worth a fair bit. It helps that JUN have deep pockets too. :) For our needs, I believe one of each gauge is more than adequate.
But of course if you want 50x gauges, then the spank factor is always good I guess :P
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
