hello just wondering i have an r33 gst-t and i wanna ask what things will i need to make it around 500 horse without nos! its 4 speed auto! I want to know whats the best ecu for the r33 apexi? and what size turbo for the price. i got 3 1/2 from turbo exhaust intrecooler apexi safc pod filter! thanks for your time and help.
(baically im a 17yr old kid and i dont have much money so if u could tell me whats cheap and what dear thankz (my email is [email protected]) :D
https://www.sau.com.au/forums/topic/57732-r33-gst-t-ecuturbo-questions/
power fc will work but not safely and happily. the ecu wont deal with the autbox and assumes its manual. sydneykid has covered this heaps of times and the gearchanges are jerky and not safe/good for the auto box. that being said it wouldn't be impossible for 500hp. youd need all the usual bolt on stuff turbo, exhaust, intercooler, injetors, clutch, airflowmeter, fuel pump, ecu, tyres, brakes, suspension work, boost controller, clutch then youd also need to up the highstall for some fun, strength the auto box, transmission cooler and a very strong auto box. speak to your local auto mechanics place and ask them how much for an auto skyline box to handle 500hp see what they're reaction is, stacks of vl turbos probably get this power all the time and they probably use simiilar auto boxes, maybe powerglide or transbrake ?
having said all that and if you were to look at powerglide/transbrake why not change to manual, then you can get easy ecu options
curly_fry_44 i am looking around 400-450hp at the flywheel, cost me around $15,000 and i got labour for next to nothing through a mate. To get that figure from your car and do it through a performance shop you will be looking around $25,000
got 280 horsepower with a boost controller i am about to high flow the trubo which will let me run alot more boost im upgrading my gear box and getting nos plus i injectors upgrade suspeinsion and i should get around 430 with nos cost around the 5000 mark so yeah
You can get manual valve bodyed and trans braked Jatcos based on VL turbo autos that handle huge power and at 500hp you need one.
The firm shifts PFC and Wolf give autos has not hurt the autos even after many years and hard driving,Quicker changes can even help the auto as its like a shift kit and the bands -clutches lock faster making for less slip and heat.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
