hey guys, im just curious to know when giving my near stock r33 a bit of a hard time i notice the boost guage sits just above the 0 mark, and the other night when going up some steep hills it pushed around +4psi... im just wondering, whats going on here :s
https://www.sau.com.au/forums/topic/57735-stock-boost-guage-on-r33/
depends what gear youre in
high gear and a hill will produce a high load at low rpm, hence, boost
try it on the freeway....sit on 5th and hit the pedal a bit...boost will rise quick but it wont feel like youre on boost
then stick it in 3rd and give it the same load. the car will feel more responsive but will be on less boost.
less torque, low rpm....ie climbing a hill, need boost to get up hill
hope that makes sense
This question has been posted over and over particularly to Skyline newbies. Your stock boost gauge is NOT in psi unit. If you look closely they were marked at 100mHg unit. +7 (the max) is 7x100=700mmHg unit or approximately 14psi.
So if you're accelerating hard and it goes up to what you think is +4 psi, it's NOT 4psi but 400mmHG or approximately 7 or 8psi, which is normal stock boost.
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
