Is anyone know where should all the wire connect to ? how to connect? Is it connect to the computerbox there locate at passenger seat there?
Another Question ..is skyline's plug using no16 size spannar to unscrew it?
And i just get a pivot tacho meter with shift light..Is the RPM signal cable connect to the computer box that locate in front of passenger seat?
thankx~~
https://www.sau.com.au/forums/topic/57875-safc2-on-r33-gtst~/
im guessing your talking about the wiring for the safc? you need to tap into the ecu wires, in the left kick panel passenger side front. you need to splice into wires meaning get a signal from a wire but not to cut it so basically tap into it.
