Hi Guys
My mate has just landed a few thousand hybrid intercoolers. 600mm x 300mm x 76mm. These coolers are exactly the same design as the original hybrid manufactures. The specs you see on those intercooler also applies here.. I will post up some spec soon.
Here are the specs
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
2 sizes
Size: 600mm x 300mm x 76mm
NEW PRICES
up to 5 buyer: $330
5 to 10: $300
10+: $295
Size: 450mm x 300mm x 76mm
NEW PRICES
up to 5 buyer: $325
5 to 10: $295
10+: $290
p&h: ~$25 to the east side of australia and $30 to the west.
As seen in the picture the cardboard box has polystyrene strips to protect the fins from transport damage. The cardboard box is even double up in places for extra strength.
Payment must be by Direct Deposit.
Local Pickup is available. Save p&h..
If you have doubt about buying from this group buy do a search for other groups buys with my name. Im sure you will find out quickly Im an honest bloke :D . Also if for some rare reason I can't get the parts and you have already transferred money to my account your money will be transfered back to your account straight away!!
Piping will be available soon for this intercooler. Soon I mean ~1 month..
https://www.sau.com.au/forums/topic/57896-hybrid-intercoolers-group-buy/
  • Replies 46
when is the end date? and how much will piping be?
Don't have an end date for this will be in around 2 weeks, depends on how many people are interests. I would like to get ten.
piping will be ~400 I believe
Update the prices... Check em out..
I will end this thread when I have 5 people. If I have an influx of buyer then 10. But there is a couple of people waiting right now so I really want to close this one and move onto intercooler group buy number 2..
I just bought a intercooler for 51jay. Really really nice cooler!!! beautifully made! The welds on it look so strong!! I'll post up a really big picture for you all to see. When he gets the cooler Im sure he wont mind you asking him. I hope!!
FAQ WARRANTY.....
If the cooler is damaged from a factory fault my supplier will replace it. No question asked. But I alway check over all the parts before I purchase them.
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
