Hey, i want the chrome front mount look but also improve cooling and its efficiency. These coolers are going for $320 + postage. Would this be hard to fit a R32 GTR? what would i need and what costs would i expect? and what other cheap alternatives could i take ?
- Polished Surface
- Core size 600x300x76mm
- Overall size 780x300x76mm
- Compressed air flow rate = 750 cubic feet/min, rated 750-800 max hp
- Working pressure = 35-40 psi
- Pressure drop = 2 - 5 psi @ 35 psi
- Hot air temp = 0-150°C
- Universal front mount fit
- Comes with mounting plates and bolts for fitment
- Core in fin (Bar and Plate)
- Hybrid OEM core
- 3" in/out end tanks
Thanks in advance
dude - hes takin the pi$$ out of you!! You want cooling properties - not aesthetics.
Its a good price for the FM alone - check out piping but, it can be costly.
You may be better off getting a hybrid kit instead.
:D
If you wanna spend the $$$ then invest in a well reputed japanese aftermarket FM.
You'll increase your cooling properties and will have a nice FM for your machine. (aesthetics and performance)
:D
:D
Until he has 300+kw, a new FMIC is a waste of money (unless there is something wrong with the current one).
LW.
leave it black, it works better heat wise by a few degrees and keeps the cops away.
that hybrid is no better than factory.The terms 'cheap alternative' and GTR don't go together very well most of the time.
I'd say a cheap alternative is a 600x300x110mm trust intercooler for when you upgrade the stock turbos to some 2530's. Then you can add some injectors, Power FC, bigger fuel pump,better clutch and start saving for the rebuild that will be coming sooner rather than later once you go for the extra power with an old motor.
Having said that I think if you would like a nice looking shiny intercooler there is nothing stopping you from getting the factory one polished. That is a cheap alternative my friend.
Maybe he wants to get 300+kw??? He did also say he wants to " improve cooling and its efficiency" !!
Sigh...
Forget what i said mate, here is what you want to hear :
Piss that stock cooler off for starters and get a Hybrid kit.
If you want to spend over 5 x more than what you had in mind, than get a Japanese brand. Maybe you will put a T78 on it one day and will really need it.
Who am I taking the pi$$ out of now...?
:slap:
Sigh...
:slap:
5 x more!! damn! Maybe if he flew over to japan and got it himself!!
A decent trust kit isnt that dear!! :D
edited
You are taking the piss out of all of us that have a dream or a goal my friend.
From greenline.co.jp :
TRUST GReddy Intercooler Kit
294 x 600 x 115 mm.
¥136,868
@80 cents per Yen, that is $1710 in Japan.
That, according to my maths, is over 5 times the $320 he had in mind.
Now, feel free to correct me, as you seem to enjoy doing.
:bonk:
Listen mate, the last thing I want to do is to turn this into a slanging match.
FYI, I am not offended, I am merely trying to correct you; although you are coming back with a different angle every time.
If you like to paddle in your canoe upstream, that is fine. Just know that there is a strong current in here.
performance.. is coming second at the moment to haveing reliability and clean body.. but it was only a suggestion.. dont just go around and say shit hes looking for cheap etc... if theres no point upgrading or degrading i wont do it.. i would rather save the $$ and get a trust one latter on..
i wont lie, i think a nice big shiny intercooler looks good.. and looks to me are important.. but to others they couldnt give a crap if the kits all hanging off and there no back seats etc.. as long as there car is going that bit faster and i have not 1 thing against these people.. god i almost envy them.. working a car aint for the faint hearted..
thanks for your comments people.. i saw the rh9 cars all running hks turbos etc and trust front mounts ? is that tellling me something about performance of trust intercoolers??
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
