Apexi SAFC2 for sale.
Included is:
*The SAFC2 unit itself
*The wiring harness/loom
*Instructions ; including wiring diagrams and instruction manual.....
*Apexi Stand
Price: $300 ono ($320 delivered)
Mob: 0421 498 792
Cheers
For pics:
http://www.skylinesaustralia.com/photopost...&sort=1&cat=500
https://www.sau.com.au/forums/topic/57912-safc2-for-300-perth/
Guest
