Hey Guys..
As part of my upgrade plan, ive got two more steps to go...
1) Up boost to 12psi, install power fc and tune
2) install Ext Cam Gear
Now - in regards to step (2), i understand that this is a mechanical retard.
My question is (sorry if its dumb) - is there any advantage to do this together/prior to the power fc tune for maximum gains....or does it matter nothing since the retard is mechanical ??
:D
There is no difference if all you're doing is replacing your factory gear with an adjustable one ;)
I have heard plenty of people with 33 gtst's getting good results by retarding the exh gear a couple of degrees. As with any modification, you are ALWAYS better to perform the change AND THEN tune for it afterwards.
Adrian
The retarding of the cam gear will do a couple of things.
First your peak power may be a a little lower, this is why people complain about no gains they are looking at the peak power dyno reading. However the boost comes on a tad sooner and the power across the boost range bar the very top end is up usually 10hp or so.
Bottom line is you will have a quicker car at the end of the tune. The guy without the cam gear might beat you in a dyno comp but, you kick his ass everywhere else that actually matters.
As mentioned you need to retune the car and focus on the mid range power timing and fuel maps.
Hi Guys...
2rismo - what you have stated makes sense - however, i wasnt sure if there was any difference between mechanical retard and overall tuning capabilities..
rev210 - the exact reason why i got them...i really dont care about the end dyno figure, just hoping for a good torque (re: 1/4 mile) result...
So - what im hearing is that it seems better to install the cam gear before the overall tune..
Thanks for the replies guys...seems like ill have to wait a while longer before i do the power fc tune... (re: ill do the cam gear install first)
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
