Hey Guys..
As part of my upgrade plan, ive got two more steps to go...
1) Up boost to 12psi, install power fc and tune
2) install Ext Cam Gear
Now - in regards to step (2), i understand that this is a mechanical retard.
My question is (sorry if its dumb) - is there any advantage to do this together/prior to the power fc tune for maximum gains....or does it matter nothing since the retard is mechanical ??
:D
There is no difference if all you're doing is replacing your factory gear with an adjustable one ;)
I have heard plenty of people with 33 gtst's getting good results by retarding the exh gear a couple of degrees. As with any modification, you are ALWAYS better to perform the change AND THEN tune for it afterwards.
Adrian
The retarding of the cam gear will do a couple of things.
First your peak power may be a a little lower, this is why people complain about no gains they are looking at the peak power dyno reading. However the boost comes on a tad sooner and the power across the boost range bar the very top end is up usually 10hp or so.
Bottom line is you will have a quicker car at the end of the tune. The guy without the cam gear might beat you in a dyno comp but, you kick his ass everywhere else that actually matters.
As mentioned you need to retune the car and focus on the mid range power timing and fuel maps.
Hi Guys...
2rismo - what you have stated makes sense - however, i wasnt sure if there was any difference between mechanical retard and overall tuning capabilities..
rev210 - the exact reason why i got them...i really dont care about the end dyno figure, just hoping for a good torque (re: 1/4 mile) result...
So - what im hearing is that it seems better to install the cam gear before the overall tune..
Thanks for the replies guys...seems like ill have to wait a while longer before i do the power fc tune... (re: ill do the cam gear install first)
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
