Oh i just did this over the weekend, turned out ok, but i am not sure what the factory specification is for it. Here are my results:
#1 - 140 psi
#2 - 150 psi
#3 - 140 psi
#4 - 130 psi
#5 - 140 psi
#6 - 140 psi
this is only rough figure i am guessing as it was only a cheap Hella Compression tester that i borrowed off a mate and he said he dunno how accuarate it is, main this is that there was no major drop across the board.
  • 5 weeks later...
I picked one up at super dodgy auto on the weekend. About $50 but there were cheaper ones. The one I got had a screw in fitting to the spark plug hole, the cheaper ones have rubber thingies you just push in and try to hold tight.
Of course good ones are much more expensive, $100+
Sorry I don't know the target compression for an rb25
#1 - 140 psi
#2 - 150 psi
#3 - 140 psi
#4 - 130 psi
#5 - 140 psi
#6 - 140 psi
Cheap gauges aren't accurate as Duncan said so these figures are a guide at best. The biggest worry is the difference between cylinders 2 and 4. Nissan recommends a maximum diff between cylinders of 14psi pretty much regardless of engine type, so these are well outside that. I'd recommend getting an accurate compression test done or, preferably, have a leak down test performed which is a far better indicator of engine condition.
Were these tests done with engine at operating temp, throttles open, etc ??
From memory you are allowed around 10% difference between cylinders, meaning between 1 & 2 , 2 & 3 , 3 & 4 , 4 & 5 and 5 & 6 not between 1 & 3 or 2 & 6 for example.
14psi max variation between cylinders is pretty much a universal spec for Nissan engines, and it's between any 2 cylinders not just pairs.
yeh i did it with WOT, but not at operating temp (for obvious reasons!) i assumed the differences could have been a factor of this cos of lack of oil in bores.
the unit i used was about ~$100 and screwed into the plug hole
mine were about 140 too... wel, 3 of em.
Two were 110... and lucky last was 70 :D
needless to say i had 3 stuffed ringlands/pistons. With the 3rd being really farked.
So 130-150 sounds ok to me. Leak down testing would show more though.
as blur said make sure the car is hot when u do it, and also make sure u have a good battery connected, (battery will affect cranking speed and compression readings)
outright readings are not important its more the variation, and if those readings were accurate your engine i stuffed, but its probably just the way u did the test. do it again properly and you should get some proper readings.
as a guide the last compression test i did on a rb25 gave figures between 170-173psi (less than 2% difference) although as i said before dont take the outright figures too seriously.
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
