Cleaning out the garage for Melbourne people...
series 1 33 gtst parts -
petrol tank FREE
rear interior panels FREE
door rubber mouldings FREE
Skyline plastic sidesteps $20
large dash pad bit exc. condition $50
rear bumper support $50
driver side mirror $50
interior door panels L & R $30 ea
complete carpet $50 (not mats)
drivers door shell $100
rear discs/ calipers $100
diff $300
rear windscreen $150
right rear qtr $250
just call 0401 598 511
pick up only
https://www.sau.com.au/forums/topic/57961-33-parts-some-free-the-rest-cheap/
