is yours a S1? Are the replacements from a S2? Because the S2 had the ignitors inside the coils, and they won't work if you already have an ignitor pack for your old coils.
yes they have to be in specific order if you leave them on the bracket. but as long as the plugs all match up to corresponding coils then I can't see a problem. Check what Morgs said. Earth is often the problem. Plus check the basics as it may be a coincedence but it might not be anything to do with your coils. might sound funny but it have seen it before. Check to make sure you are getting fuel and spark. Have you got a HEI (High Energy Ignition) tester? if so.....use this to test your spark. If not...go and buy one...they only cost five or ten dollars and it'll show you if you're getting the required spark from the coils.
hey guys.. f**k knows what the go is..
ive put the old (no good coils) back in, and it fires strait up..
try with the new coils. and nothing.
its got me stumped. so the cars still running like shit. and ive got these coils ive just purchased that appear to be no good to me.
they came from a S1, but are defently differant.
My S1.5 (S2 engine) has '533' coils and I have a S2 coil (from a S2 car/engine) that had '6xx'.
Sounds like you have the wrong coils (ie your mates car was a S1.5 with a S2 engine and your car is a S1).
pull off a rubber boot from one of your coils, and one of the purchased coils.
I purchased some that were missing the little spring that sits inside the boot, and the ones I bought had corroded / stained metal.
I cleaned them up with bi-carb soda and steel wool, then put the spring in (dunno if the spring makes a difference) and they worked a lot better.
But from the sounds of it, sounds like u got the wrong coils
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
