Hi guy's I feel abit of a dic#k, I just bought a RB25 turbo and the shaft has alot of play in it. I e-mailed the guy I bought it from and he said that RB25 turbo's are bush bearing not ball bearing. I would have bet my left ball that RB25 turbo's were all ball bearing. What's the go????? Hope I didn't get ripped off.
Thanks for any info!
https://www.sau.com.au/forums/topic/57982-rb25-turbo-all-ball-bearing/
Yes they are BB and will have a bit of shaft play.I don't have specs on how much play is acceptable thou.Once the core has got oil thru it some play goes away.
If it is a RB25 turbs the guy knows nothing about them.
BB=bush bearing, not ball............I think R34's are ball.
Also early r33's were ceramic vanes, later ones were steel, R34 are plastic [or so i've read].
Steel is best, plastic next, they say ceramic tend to break after a while.
You can send the turbo to GCG in Condell Park Sydney and they will convert it to ball bearing and hiflow it for $1200 to $1900.
series1 r33 came with metal compressor wheel
series 2 came with nylon compressor wheel (so did r34gtt)
both came with ceramic exhaust wheel.
I cant say for sure whether they are ball bearing but i always thought they were. the one on my old car had a bit of play i had it for 20,000kms no problems. they are cheap anyway just use it and dont worry about it.
trident i think your confusing the inducer wheel with the turbine wheel
the s1 has a alloy inducer, ceramic turbine and the s2/34 are polymar inducer with ceramic turbine
they are ball bearing not plain bearing, even if it were a plain bearing still doesnt justify play in it as ballys have more play from factory...... is it thrust play (in out)?
Think again , ALL R33/34 RB25DET's came from Nissan with a Ceramic turbined Hitachi Ball Bearing turbo .
Late model S2 came with steel front and back std, I know, I just had mine out. I have pics.
As for ball vs bush, I was only repeating what I was told, I could have been wrongly informed.
your's must have been rebuilt then!!
OOOOHHHHH NNNOOO,,,,,,,,,,,,,that's not right, my car only had 40,000km on it................................lol
It could have been, or maybe they changed specs. I've got a '98 R33 40th, the last of them, they were virtually making the R34 next to them [figure of speech].
I really don't know, I only know what I have seen on mine, and assumed other late model R33's had the same.
stock 95 model. ceramic exaust wheel, 64,000 no play in the bearings in mine. Had it off recently. So dont know whats wrong with the one you bought, go take it to pro and have them look/test it for tolerances
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
