Sorry, another iPOD question. (Yes I've searched!) ;)
Hi All,
Ok, I've done a review on every iPOD post on this forum, but there is one thing not clear.
I intend on using my stock OEM HU, due to theiving ba$tard$ having stole my Alpine 7998R. >, so I am thinking of hooking up my iPOD so that I can still have mp3's.
Now, what I'm after is a clean installation. I don't care, that I cannot use the HU controls for my iPOD, but I prefer not to go down the path of FM transmitters or tapes.
So, as this is an OEM, I do not have any aux inputs. I now own a R33 Skyline, so the original unit came in 2 bits. Radio and tape in one din, but as a seperate unit, there was also a CD player. Which from what I can gather, the input is the same as a CD stacker.
So what interests me, is that I have heard that somehow, you can use the line out of an iPOD (docking station) and convert it into an RCA output. Then from your RCA's convert it the CD stacker input.
Is this correct? Now, the docking station is by now way meant for a car, but I still want to use the line out (refuse to use the head phone output) Is there anyway of doing it, outside of expensive aftermarket designs. You know, like hacking up some cable or something???
Anyway, another thing is that I don't know whether my OEM unit has the traditional stacker input. I have attached a photo here for your reference. The unit on the right is the tape deck, and has the input, the unit on the right, is the CD player, where you can see the cable pins. I guessing even if I did use this input, I'm going to still need to power the iPOD up seperately right. How can this be done??? (Battery maybe)
Anyway, please advise if this can be done.
Thanks heaps.
The screenshot you've posted is the whatever-bus connector/port for cd changers.
I have no idea how you'd splice this from an ipod dock but the way you said seems possible.
Ipod dock> rca> your cd thing
Now - as far as I know the cd thingy (the connector in your photo) is proprietry. They all look the same but I've been told some are different. Unfortunately I'm not too sure about those as I've never had or played with a stacker.
What I can say is that there is info on the net to make the ipod dock go to RCA. So if you can find the pin layout for your cd stacker connector and can make it into rca then you should be right.
Barring that you could just do away with the RCAs if you could find the ipod dock connection and use a generic firewire plug in thing and do it direct (if ya get what I mean).
For everything except making your cd stacker connector thingy into RCA you should be able to find in this section of the forum.
use the headphone out on the ipod run that to a 5 pin plug . there is a control lead that will have to go to +5v to make the main unit switch over . if you have a multimeter and a bit of time you cna sort it easily. only issue you will have is engine noise.
If I had one of the units I would pin it out for you.
power wise I would suggest a battery to avoid the engine noise issue.
yes it can be done as the cd unit puts out a .5 - 1 v signal to the main unit. the headphone jack will serve as a 'gain' control of sorts.
FM docking station to RCA. done it. works ok but is a pain in the ass to get right. best to make a cable.
show me a pic of the front of the radio and I'll see if I can find one up here.
Chris, you're a legend,
I guess, if it would be easier, can I just ship the whole damn thing to you. I'll send you the HU, all cables and jacks that I already have, as well as enough money for you to send it back cable and all. What do you think?
Else, I'll take a photo of the front anyway........ but yeah, from the sound of things, i do not have the expertise to know what I'm doing. Multimetre, whats that?? :)
Anyway, thoughts??
Thanks again for your assistance
best thing you can do for ipod connectivity is to buy a belkin f8v7058-apl
it plugs into the cig lighter, and has a socket in it to plug in for tape connectivity.
i then hacked the cig lighter thing apart, and pulled out the line level wires and hooked into the aux input on my pioneer. wire in to a +12 behind the dash, and just leave out the cord to plug into ipod. make for a very nice and neat install.
now your only issue will be the aux input on the std unit !
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
