Sorry, another iPOD question. (Yes I've searched!) ;)
Hi All,
Ok, I've done a review on every iPOD post on this forum, but there is one thing not clear.
I intend on using my stock OEM HU, due to theiving ba$tard$ having stole my Alpine 7998R. >, so I am thinking of hooking up my iPOD so that I can still have mp3's.
Now, what I'm after is a clean installation. I don't care, that I cannot use the HU controls for my iPOD, but I prefer not to go down the path of FM transmitters or tapes.
So, as this is an OEM, I do not have any aux inputs. I now own a R33 Skyline, so the original unit came in 2 bits. Radio and tape in one din, but as a seperate unit, there was also a CD player. Which from what I can gather, the input is the same as a CD stacker.
So what interests me, is that I have heard that somehow, you can use the line out of an iPOD (docking station) and convert it into an RCA output. Then from your RCA's convert it the CD stacker input.
Is this correct? Now, the docking station is by now way meant for a car, but I still want to use the line out (refuse to use the head phone output) Is there anyway of doing it, outside of expensive aftermarket designs. You know, like hacking up some cable or something???
Anyway, another thing is that I don't know whether my OEM unit has the traditional stacker input. I have attached a photo here for your reference. The unit on the right is the tape deck, and has the input, the unit on the right, is the CD player, where you can see the cable pins. I guessing even if I did use this input, I'm going to still need to power the iPOD up seperately right. How can this be done??? (Battery maybe)
Anyway, please advise if this can be done.
Thanks heaps.
The screenshot you've posted is the whatever-bus connector/port for cd changers.
I have no idea how you'd splice this from an ipod dock but the way you said seems possible.
Ipod dock> rca> your cd thing
Now - as far as I know the cd thingy (the connector in your photo) is proprietry. They all look the same but I've been told some are different. Unfortunately I'm not too sure about those as I've never had or played with a stacker.
What I can say is that there is info on the net to make the ipod dock go to RCA. So if you can find the pin layout for your cd stacker connector and can make it into rca then you should be right.
Barring that you could just do away with the RCAs if you could find the ipod dock connection and use a generic firewire plug in thing and do it direct (if ya get what I mean).
For everything except making your cd stacker connector thingy into RCA you should be able to find in this section of the forum.
use the headphone out on the ipod run that to a 5 pin plug . there is a control lead that will have to go to +5v to make the main unit switch over . if you have a multimeter and a bit of time you cna sort it easily. only issue you will have is engine noise.
If I had one of the units I would pin it out for you.
power wise I would suggest a battery to avoid the engine noise issue.
yes it can be done as the cd unit puts out a .5 - 1 v signal to the main unit. the headphone jack will serve as a 'gain' control of sorts.
FM docking station to RCA. done it. works ok but is a pain in the ass to get right. best to make a cable.
show me a pic of the front of the radio and I'll see if I can find one up here.
Chris, you're a legend,
I guess, if it would be easier, can I just ship the whole damn thing to you. I'll send you the HU, all cables and jacks that I already have, as well as enough money for you to send it back cable and all. What do you think?
Else, I'll take a photo of the front anyway........ but yeah, from the sound of things, i do not have the expertise to know what I'm doing. Multimetre, whats that?? :)
Anyway, thoughts??
Thanks again for your assistance
best thing you can do for ipod connectivity is to buy a belkin f8v7058-apl
it plugs into the cig lighter, and has a socket in it to plug in for tape connectivity.
i then hacked the cig lighter thing apart, and pulled out the line level wires and hooked into the aux input on my pioneer. wire in to a +12 behind the dash, and just leave out the cord to plug into ipod. make for a very nice and neat install.
now your only issue will be the aux input on the std unit !
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
