My R33 GTS25t is on the ship from Japan at the moment, and it has some aftermarket rims that I believe are 8.5" wide on the rear. I understand that the widest available rim on a GTS25t was 6.5" at the rear.
According to VicRoads I'm only allowed to have 7.5" wide rims (as it's 1" wider than stock), so I need to get an engineer to certify that they're OK.
Has anyone done this before? Is there any chance of the tyres rubbing (255 on rear) or anything like that, which might mean the engineer won't give me a certificate?
Thanks!
https://www.sau.com.au/forums/topic/5806-wide-wheels-engineers-certificate/
i had 265's on the back of my skyline - had no rubbing probs.
legality wise, you will need to get it engineered, not usually a problem - but wait til you have a fair few mods on it and get them all engineered.
Thanks for the info. However, I have to get it engineered straight away as it will be unroadworthy otherwise, and not insured. From what I've found so far, it will only cost me a couple of hundred anyway (I hope!).
u may get away with it as on my tyre placcard, there is a 16"x7.5" wheel as well... i believe these wheels came on something to the sound of an lsd-equipped auto? someone please clarify... nonetheless, i'm seeking to get an engineers cert on my wheels, too (9" rear, no way out)... does it cost the same to engineer other stuff at the same time? i.e. exhaust and fmic?
cheers,
louis
*cough* temporary stock rims for compliance *cough*
My problem is not compliance, it's roadworthy and insurance. If your car isn't roadworthy, it's not under insurance either. Plus I could be defected I suppose.
Interesting. Does anyone know if wider wheels are an option on the gts-t?
no wheels were an option... if you didn't like the stock ones, you could get the stock ones!
I do believe if u get an engineers report it is legal. Only bit of advice i can give is if u do get an engineers report approved make a photocopy of it laminate it and stick it in your glove box. Some cops will rip up anything u hand to em :]
Other than that u r screwed.
I reckon if they dont hang out the guards u shouldnt have a prob getting it engineered :]
Just because you're 'insured' doesn't mean they know about your rims being unroadworthy. That's the problem - insurance companies don't care until you have to claim.. then they REALLY care.
Ignorance is bliss I suppose. I wish I didn't know about this problem, but now that I do I can't bring myself to ignore it!
Yeah I reckon maybe you could claim the GTR width being the stock width maybe.. I'm under the impression that the tyre placard is no official source of info though as it's up to the CPA what goes on there.
the tyre placcard will save u from a defect but that's bout it... if the dimensions of ur wheels conflict the standards set out in the adr, then technically ur car is not roadworthy and any insurance company will try to make a policy void by looking out for such stuff... a mate of mine had an e36 318i with no engine mods, just bodykit, lowered and 17s... the car got vandalised on the street and when he lodged the claim, they rejected it bcos his wheels were 8" wide... even in a claim that wasn't a result from an accident was rejected bcos the was not roadworthy... duty of disclosure states that u have to mention everything to ur best knowledge, but being ignorant or feigning ignorance is not a valid excuse to insurance companies... back to the tyre placcard issue, my r33 has the orig jap placcard on the driver's side that lists the 7.5" wheel and the locally translated one in the glove box also has that so u may be able to get ur rwc...
Thanks for the info Lou. You say the original Jap placard listed a 7.5" wheel. Does the placard list all the stock wheels available? So if the placard has a 7.5" wheel, I assume that would mean I can fit 8.5" according to VicRoads.
I will have to find out what the japanese tyre placard states when it gets here.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
