  • 4 weeks later...
Power Restiction For P-Platers In Vicroia: 125kw/tonne
From May 1989 to 1991...
R32 Gtst Type - M Sedan (Manual)
Power:158Kw
Weight: 1290kg
Power/Weight Ratio: 122.48062015503875968992248062016kw/t
Under Power Restictions
R32 Gtst Type - M Sedan (Automaic)
Power:158Kw
Weight: 1310kg
Power/Weight Ratio: 120.6106870229007633587786259542kw/t
R32 Gtst Type - M Coupe (Manual)
Power:158kw
Weight:1260kg
Power/Weight Ratio: 125.39682539682539682539682539683
Over Power Restrictions
R32 Gtst Type - M Coupe (Automatic)
Power:158kw
Weight:1280kg
Power/Weight Ratio: 123.4375
Under Restictions
I worked out that from an RB20DET which produces 158kw that to be spot on the p/w ratio the weight of the skyline would have to be 1264kg's... so: If the skyline is under 1264kg's then it is OVER (Illegal) the p/w ratio, but if the skyline is heavier than 1264 it is UNDER (legal) the p/w ratio. I used to think if the skyline is an r32, and its a gtst then its legal but the one exception is for the 2 door 1989-1991 gtst wich weighs 1260kg. But, from 1991-1992 the weight increased to 1320kg making it legal. BUT, does the restriction include the weight of the driver, because the 89-91 2 door gtst is 4kg's under...
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1150736
  • 3 weeks later...
it's based on factory quoted output, and does not include weight of driver. The p/w ratios you have there are what they use.
Also note, that the only skyline on the vicroads list of restricted cars is the '32 GTR, because it was the only skyline released on the australian market.
Most cops don't know that 33 gtst's are not legal for pplaters - though i'd imagine TMU cops would have a fair idea.
As mentioned before, maybe you should have found out if you could drive it *before* buying the car. Did you have a question, or were you just whinging?
You could drive it on p's, but just keep in mind if you make an insurance claim, the insurance company could say that you were driving unlicensed. as you wernt licensed to drive that particular car.
The only way i can think of to get around that rule, would be to buy an R33 GTS, and put in an rb25det.
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1182396
How Many Times Does It Have To Be Said?!!
It Is Factory Weight... Taking A Shit, Taking Out A Spare Wheel, Or Sticking A Sticker On It That Says 2000kg Doesn't Make You Any More Legal. And the cops won't accept that for one second either.
Get Over It!! You Are Not Supposed To Be Driving These Cars in lovely victoria.. And Cops Will Punish You If You Do. You'll Be Selling Your Car Before The End Of Your P-plates Anyhow... if it even survives that long.
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1183278
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
