Hey everyone,
Im kinda a n00b so b nice to me. Wondering if u can help me out with a few Q&A
I gots a 1993 180sx, Sr20det, automatic mind you, 48000kms, everything completely stock. Im looking to modify it a little, id like to go to town on it but im kinda at uni so a bit strapped for cash atm, just bought a new set of performance dunlops and that took out alot of the bank account. With that in mind ive asked a few ppl about it, and m told that basically i should get a pod filter hooked up (mercury motorsport qouted me 250bucks) and a blow off valve if i wanna show it off a bit.
Bare in mind, its auto remember so will a blow off valve work ok? Turbosmart says yeah go for it, but ive heard go with a HKS super sequencial. But with driving an auto can the BOV be heard ok and work alright on an auto?
Also, in besides saving for uni payments and crap, ive been told go for a sports exhaust system, but that will set me back like $1500, and i just dont have that kinda cash, so will spending 250-300bucks on just a 2.5 - 3inch tip b ok at the moment?
Anyone give me some ideas on wat i can do for my 180 at the moment that sint overly expensive? any ideas would b great.
also, on another note, im curious as to how much my baby would b worth,
completely stock
1993 180sx
SR20det
automatic
48000kms
Pearl white
new dunlop performance tires
cd player
blue neons fitted under dash and on rear pillars + strobe light
anyone enlighten me?
thanx
https://www.sau.com.au/forums/topic/58080-1993-180sx-sr20/
A few years back I owned a 5spd '93 model for just over a year. I ended up putting on a 3" exhaust, very nice gain in power (but oh so droney). It had the factory airbox on it, but I opened up the front of the box, which made a noticeable difference. I also installed a bleed valve and increased the boost to around 10-12psi. This made the car go nicely, but it drove like a V8. I had crap tyres and the Silvia suspension is terrible by comparison to an R32 (which my best mate had and was noticeably faster around corners).
After doing this mods, the car was in desperate need of a tune, which I never did. I sold it in 2000 for $15300 and it was a straight fairly good example, but prob around grade 3.5
My advice, based on your budget, would be to buy some used suspension for the car and make it perform better, before you go making it go faster.
Mark
PS I prob won't be back to this thread, if you want to talk more, pls PM
https://www.sau.com.au/forums/topic/58080-1993-180sx-sr20/#findComment-1119631
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
