  • Replies 52
I have had several different grilles come in on different cefiros.....i recently had one come in with a slat type grill.......i think it may be from an S13.....it fits perfect though.
I have also seen and S13 with a factory cefiro grille.......it was in a picture but it seemed to fit quite well.......Perhaps if you visit a bodykit shop that sells the lat type grills they will be happy to test fit an S13 grille into your car to ensure a decent fit.
https://www.sau.com.au/forums/topic/58090-cefiro-grills/#findComment-1115883
no the nismo grills are an entire 40mm shorter than the cefiro grills i have measured them up, it would be easy to cut in half then fibreglass up though...
an easier way to do it however is take the grill off a skyline r33 and simply cut them down to siz and cover the seam up with bog, if you can be bothered that is...
riverside is the silvia you refer to with the ceffy grill in issue 1 of drift battle magazine? it's like black or something?
it's an OK fit because the lights are pushed out 20mm either side of the body brutha!
https://www.sau.com.au/forums/topic/58090-cefiro-grills/#findComment-1117181
  • 4 weeks later...
Hmm. Without the middle bit. I had a look at the pics nark is it custom and re-moulded, fully custom or is it a OEM option?
I need to do something with mine (when it gets out of the shop) for more air flow to the radiator, and ripping that thing out seems the best option. Off course replacing it with slats or a grill would be nice so I don't have arseholes opening my bonnet on the street.
https://www.sau.com.au/forums/topic/58090-cefiro-grills/#findComment-1147077
