  • Replies 52
the "import wreckers" near me wanted $170 for the skyline grill
mind you it's run by vietnamese folk who when they see whitefella like me come in it's a bit like "oh harro! here come shtuupid white kid! ret's see how much we can freece him for! har har"
if you're thinking about going ahead with the project good luck and make me one too while youre at it,
if i was to change grills myself i would definately go this way aobut it, falinign that get the laurel style grill....
perhaps it would be feasible CC if you looked on the SAU classifieds?
Heh I'm down with the Vietnamese yo.
eg. ceffo hooked me up with $6 a brake disc machining etc :(
Still $170 can go **** itself. I think I'm getting the slat grill from Slain so I'll leave it at that for now. If I happen to stumble onto the skyline grill for cheap I might have a look at it again.
Good to know what it is now though :)
i think i know where you went...just got all my discs machined for $24...best find of the century me reckons
eg. ceffo hooked me up with $6 a brake disc machining etc :)
Someplace on some main road of cabramatta or something. It was mad the discs were so freakin smooth it was smoother than some girls butts I've lic... err touched.
There's also a good parts place around a couple of corners from that as well. Found 2 works 16x8 (doriftooo) rims there the guy wanted $200 with some crappy tyres on them. I though that was ok but I couldn't afford it at the time :)
woohoo... got an R33 GTSt grill today for free, will be doin some light fibreglassing to make it fit the ceffy :)
take out the middle slat, shape it back to an open grille, then fibreglass over it, gel coat and then paint... then put a black mesh behind it and mount the cefiro badge off the stock one off to the side. Booyeh
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
