discopotato03 Posted December 8, 2004 Share Posted December 8, 2004 I don't know anything about this one . Can someone tell me the specs like bore , stroke , journal sizes , rod length , gudgeon pin diameter and block height . If it has a forged steel crank and suitable dimensions it may be useful . Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/ Share on other sites More sharing options...
proengines Posted December 9, 2004 Share Posted December 9, 2004 bore: 85mm stroke: 83mm Bearing sizes and bearings are the same as a RB30. The rods would be no use in a performance engine as they run a huge piston pin, 26-27mm-ish from memory and the rod is way too heavy. The crank is forged steel, not sure about snout/flywheel pattern. It would be top quality being a diesel as they are under a lot more load than a petrol engine, diesels also usually have larger radiuses on the journals although the RD28 might have fillet radiuses but i'm not sure on that. The head gasket is very similar to an RB30, the bolt pattern is the same, I use the same plate to pressure test both. The RD28 uses a MLS head gasket which might be worth having a look at to use on an RB, it's available in 1.42, 1.5 and 1.58mm to set piston to head clearance on the diesel engine. Thats about all I can tell you without having one here to look at. Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1116296 Share on other sites More sharing options...
discopotato03 Posted December 29, 2005 Author Share Posted December 29, 2005 Can anyone tell me if the RD28 block is the same deck height as the RB30 ? Also was it cast thicker in the bores allowing larger rebores or did it use liners . Curious to know if more than 3L can be had without huge cost for same external dimensions . Cheers A . Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1821688 Share on other sites More sharing options...
ebola Posted December 29, 2005 Share Posted December 29, 2005 Hmm - a diesel powered skyline....... Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1821912 Share on other sites More sharing options...
Josh Posted December 29, 2005 Share Posted December 29, 2005 I would assume(Going on the knowledge of the engines we have at work) That it being a diesel would have a much thicker block to cope with the greater compression ratio and heat produced.. I imagine that would help with boring it out to a greater capacity... Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1821966 Share on other sites More sharing options...
shaunr32 Posted December 29, 2005 Share Posted December 29, 2005 very interesting - have you been in a car witht eh engine. my old man has one in his 2000kg patrol. stock standard this thing pulls from 2000rpm (full boost by 2100rpm along with max torque) redline is at 4600rpm !!! interested to know what its limits are and how much power you can get out of it about 96kw 250nm torque - standard not interecooled Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1822661 Share on other sites More sharing options...
Sydneykid Posted December 29, 2005 Share Posted December 29, 2005 (edited) We had a good long look at one of these about 5 years ago, there were some reasons it got rejected as a possibility..........mmmmm........they don't have block mounted oil squirters.........the crank has no provision for cam belt drive maybe......or was it oil pump drive.......hamonic balancer perhaps, not sure about main bearing cradle. There isn't any foreseeable advantage over an RB30, the stroke was shorter (83 mm versus 85 mm) and the crank tested up much the same for hardness, same size bearings etc. I think there is still one kicking around ther machine shop somewhere, I could always dig it out and refresh my memory. cheers Edited December 29, 2005 by Sydneykid Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1822669 Share on other sites More sharing options...
discopotato03 Posted December 30, 2005 Author Share Posted December 30, 2005 (edited) Thanks all , I was just curious to know if the RD block would take all the RB30 internals but allow larger bore cylinders for the same external dimensions . I've not looked at an RB block for a while so I'm not sure how much meat there is between the cylinders . SK did the workshop test that one for core thickness ? Thanks A . Edited December 30, 2005 by discopotato03 Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1824190 Share on other sites More sharing options...
Sydneykid Posted December 30, 2005 Share Posted December 30, 2005 Thanks all , I was just curious to know if the RD block would take all the RB30 internals but allow larger bore cylinders for the same external dimensions . I've not looked at an RB block for a while so I'm not sure how much meat there is between the cylinders . SK did the workshop test that one for core thickness ?Thanks A . <{POST_SNAPBACK}> We didn't cut one up, since it was an N/A diesel (not a turbo) the concensus was it wouldn't have much extra meat. Plus the water jacket isn't overly large anyway. so not a lot of room to move. cheers Link to comment https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1824888 Share on other sites More sharing options...
