Has anybody else had issues with afm before?
about 6months ago i was having major issues with the car idoling at 2000rpm and not reving above that when accelerating. Afm was changed after a week of testing everything and that fixed the problem, Now it seems its starting to do it again and its driving me nuts. What are the odds of having two Afm stuff up with in 6months in exactly the same way??
Can anyone help me out ? Any ideas?
thanks
tim
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/
hi, check your TPS sensor plug that connects to the throttle position sensor. My car idled at 2000 rpm one day when the plug 'was left unconnected' and wouldnt accelerate cleanly. I thought something had gone majorly wrong, but once I plugged the tps plug back in all was sweet. I think the computer uses some of the other info to make an estimate on the fuel should the sensor fail, and runs a safer tuning map for the engine as a precaution.
It could also be the AFM, try cleaning the thin wire in the centre of the AFM with CRC contact cleaner, it is supposed to 'self clean' once the ignition is switched off by rapidly heating the wire to burn off any deposits, this probably isnt working so good after 10-12 yrs especially if you have an oily aftermarket air filter in there. It could also be the solder inside the square box attached to AFM, it could be dry when wires conect to the pins that the plug connects to. If you are sure that AFM is no good and are going to buy another, give it a go at repairing it, check the forums for some info. Just make sure when you are doing the soldering that you dont let too much heat get anywhere else( use heat sinks).
I did mine years ago and it is still going strong.
Stephen
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/#findComment-1117005
WD40 is the worst thing you can spray it with as it will leave a residue on the wire and distort the reading. Maybe even damage the AFM. Use something like Carby clean or throttle body cleaner or for a more expensive alternative, try using that Contact crap.....never WD40 though.
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/#findComment-1118148
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
