Nasho runs 0wn j00!!!
  • Replies 209
Originally posted by tactic
oh and the 2nd time he was running 15psi
1st run was 12psi
well done :)
Hey tactic i was in Donnies car!
u noe the 1st race!
Did u c da F**KING fireball that blew outta Donnies exhaust??
i saw the flames from the bakseat man!
:eek1:
Originally posted by skylark
Had a blast! came home about 4 I think, didn't sleep, just played GT3 until it was time to go to work. That cruise ranks up there for me!
DON91E, I think we have a funny home video on our hands? Oh yeah and the POPGUN will be back again to fight another day, win loose or draw.
The train of headlights through Holsworthy was impressive and skylines three abreast down the Pacific Hwy on the way to the Nasho felt good to be apart of.
You know you're having a good time when you look at the time, it's 3.30am, you have to be at work in 4 1/2 hours but your havin so much fun you just don't care.
Thanks to all who came
   Rhys.
Hey Skylark it was good to meet you and your brother.
I want to see your brothers R31 next time ok!
Talk about us being early birds there hey? hahaha
Originally posted by XCUZME
minh, is pho your secret? damn man, i'm going to order a lifetime supply of pho to try and beef up like you, the roids just aint workin for me :lol:
George. I told you before You must take it analy! LOL
You dont sniff it! hahahaha:lol:
Originally posted by SDU4EVA
Hey Donnie!
In one of the pics I noticed Predtor!
Did someone finally tell him about SAU?
That was the pic i took, the place was so dark i needed the flash to find my car !!! hahaha so i ended up taking pics of everyones car there.. well as many as i could hahaha
u missed out min!!
i got some clips of chippy too if anyone wants them.. not gonna post it anywhere just in case u know
:):( hahaha
Guest Nightsky
It was good to meet you and everyone else Minh. Although I wasn't driving I still had a very good time. Next time i'll have the R31 with me, I just didn't want to do a natio run with a bad shock absorber.
Thanks to all for being hospitable to a newcomer. :)
Sweyn.
D3VIL enough about my driving :)
*edit* I could have sworn I saw a post here by D3VIL...
*edit edit* Sorry I'm getting my threads mixed up.
I did improve as I did more launches. Since I got the car I have not launch it properly at all! I thought it would be a good opportunity to get to know the car.
I had abit of dramas with overheating at the end of the night but it turns out the my radiator cap was stuffed. It's amazing how a cheap bit like that could have destroyed my engine if I had not been careful :)
I have a new radiator cap now and am back on the road.
Zman can you send some of the clips of chippo if there were any with my car to [email protected]. Thanks.
Welcome to the new people on the forum... well the ones that have finally decided to post and not lurk :(
Getting threads mixed up? hahah Marvin the speed is getting to your head.
Why didnt June come last night?
Lucky your car is ok.
Did you have a good time champ?
minh, my mate michael (ntimd8) is mates with pred8r, he called him to meet up with us afterwards. he joined us at stanwell tops....
dont think anyone told him bout the forum tho :)
taking pho anally? ummm. i'll stick to my protein powder and creatine hahaha
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
