Hello all
I have holidays right before xmas for 1 week. I want to get mods like : Intercooler, boost controller, heavy duty clutch, computer, pod filter done in one hit. How long would you say it would take to get those things done and then dyno as well?
Is that amount of time going to be enough? I live 500kms from perth :) Hence the reason I have limited time up there.
Thanks
Glen..
https://www.sau.com.au/forums/topic/58159-mods-for-an-r33-gtst-time-to-do/
intercooler takes an hour and bit to fit roughly.. thats a DIY jobbie though using a KIT like the Hybrid one...boost controller.. if manual is very quick.. electronic is a bit of stuffing around.. so 2 hours or so there. computer same thing..plugins you can plug in yourself.. 15 mins... or a workshop doing the dyno tuning will do it all for you..clutch sorry cant help there. pod filter is about 15 mins...if you have the afm adaptor. and that will include removing the old airbox..
yeah id ring the workshop up two months notice to get all the parts in for you (since you are wanting quite a bit fitted to the car). Then id say fitting probably wouldnt be anymore than 2 -3 days depending on the workload of the workshop. But there are people on here that own workshops that can clarify for you. Im just guesstimating.
The more organised you are .... the more organised the workshop can be and the quicker things can get done. Know exactly what you want on the car .... there are many different kinds of ECU, FMIC, Boost controllers etc out there.... if you arent ordering in the parts yourself - then give them plenty of notice to get them in for you. :)
Or if you want.. get a hole saw and a drill
get an intercooler kit there are cheaper ones advertised on here i think but you can get a hybrid kit for $1150 and thats with polished aluminium pipes and includes hoses etc.. and full instructions including pictures.
That will take you a couple of hours to fit.
and about 3 days to get delivered to your door.
same goes for the boost control you can get it on the same delivery for about $360 or something
same goes for the pod filter.
take a weekend to get the cooler and pod fitted and then drive down to perth and get the boost control and the ecu and the clutch fitted.. a clutch place can do it if you book it in etc and then you can pick it up or wait there and then go to a workshop for ecu install and tune.
it cant be that hard..just get to planning
You can actualy get all these mods done in Bunbury if it is easier, quiet a bit closer to your current location, bart from south west brakes does good deals on the clutches same day install, and the rest can be handle by a number of different companies Adrenalin Performance are a group of guys no nonsence but there are plenty of great shop in perth to. Best of luck with the mods
if you want to bore out your cylinders for extra power you can put exactly 100 grains of sand into your fuel tank and that will go through the system and you will notice the power gain within two weeks
no idiot, this only works with diesel
so fill her up with diesel first ok
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
