Hey guys,
im having a bit of trouble with my drivers side window in my R33.. it's getting very slow and the switch is a bit of a pain... any one got suggestions... could it be the motor is packing it in or needs a look at??? If i replace it anyone know how much a motor will set me back???
Cheers
Matt
https://www.sau.com.au/forums/topic/58160-driver-window/
have u done a search yet?? theres been a number of threads lately and i seem to keep on repeating myself:D
yes i think ur motor is probably gonna pack itself and a motor will cost u from $120 - $160 or more depending on where u go. could be either bad switch or loose or over tightened window arm mounts. the search button is ur friend use it!!:)
https://www.sau.com.au/forums/topic/58160-driver-window/#findComment-1116383
Yeah ive replaced my window regulator but mine electrically functioned fine. When i replaced the window regulator it was pointless because it was just one of the bolts that runs through the window that had snaped, i thought it was a rail. If you want to try my window control unit on your car just pm me, otherwise if its your reg ive got a spare also il sell cheap.
https://www.sau.com.au/forums/topic/58160-driver-window/#findComment-1116647
