Excedy <-- think thats how you spell it, Heavy Dutch goes for around $450ish (not include install)
Excedy Sports Organic around $800ish
installation depends on the guy, i think around 200-$300
hope that gives you a rough idea,
on extra HD i really dunno
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1116527
$800 is probably for both plates - pressure and driven.
I got a new lightweight flywheel + HD pressure plate + ceramic standard plate (all Exedy stuff) last April for just over $1G from Adelaide Brake & Clutch
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1116835
Nick performance clutches NPC in Brisbane will build a organic plate clutch with a 2600 pound clamping pressure which will be good for close to 300rwkw for $533
Will feel and drive like a factory one.
I will be getting one of these very soon.
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117573
Hey Darrin, I finally got the flywheel put in, I've lost a bit of torque over 5k.
Have you noticed the same?
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117630
I am waiting for my stock clutch to die first, then install the new flywheel and new clutch.
There is a chance I may be installing a Excedy twin plate that I have had rebuilt instead, so I will not need the new flywheel.
Dose the engine rev quicker with the new flywheel?
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117859
thanks for the pointer darren.. I'll need a decent clutch when i do my manual conversion later on so might give these guys a call.
With clutches, it depends what they replace.. but yeah, like somebody was saying - often they include a heavy duty pressure plate with the driven plate which can account for the varied costs. When you step up from "standard" to a heavier duty pack generally u have to change that as well.. but if its just rebuilding a standard one.. or you have good "exchange" gear that'll drive the prices down.
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1119826
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
