Excedy <-- think thats how you spell it, Heavy Dutch goes for around $450ish (not include install)
Excedy Sports Organic around $800ish
installation depends on the guy, i think around 200-$300
hope that gives you a rough idea,
on extra HD i really dunno
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1116527
$800 is probably for both plates - pressure and driven.
I got a new lightweight flywheel + HD pressure plate + ceramic standard plate (all Exedy stuff) last April for just over $1G from Adelaide Brake & Clutch
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1116835
Nick performance clutches NPC in Brisbane will build a organic plate clutch with a 2600 pound clamping pressure which will be good for close to 300rwkw for $533
Will feel and drive like a factory one.
I will be getting one of these very soon.
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117573
Hey Darrin, I finally got the flywheel put in, I've lost a bit of torque over 5k.
Have you noticed the same?
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117630
I am waiting for my stock clutch to die first, then install the new flywheel and new clutch.
There is a chance I may be installing a Excedy twin plate that I have had rebuilt instead, so I will not need the new flywheel.
Dose the engine rev quicker with the new flywheel?
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1117859
thanks for the pointer darren.. I'll need a decent clutch when i do my manual conversion later on so might give these guys a call.
With clutches, it depends what they replace.. but yeah, like somebody was saying - often they include a heavy duty pressure plate with the driven plate which can account for the varied costs. When you step up from "standard" to a heavier duty pack generally u have to change that as well.. but if its just rebuilding a standard one.. or you have good "exchange" gear that'll drive the prices down.
https://www.sau.com.au/forums/topic/58175-clutch-prices/#findComment-1119826
