Ok, well I as in the passenger with Malvin for this race,
And by 3rd gear we had flew pass the blue 180 n by 4th, we were about duno about 3 car length in front b4 we hit the round about....
N im sure George would agree with me here, cause he was standing closer to the finishing line as well..
I heard the blue 180 put his blinkers on, but I dont understand why, when we flew past him.....
Nearly all malvin races, he had given all his opponent at least a 2 car head start.. due to his immaculate launching... :)
Just kidding mate....
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88250
I have never seen FeelDG run. I have not been out to the runs alot though. I hear he only runs for money that's why he doesn't muck around like the rest of us.
If anyone knows any differently please correct me on this one.
If it is the case then its just to serious for me I just like to enjoy the car that I have that's all.
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88326
you never see feeldg run!? HAHAHAH.
you should have seen him when we left!
he was giving it hits in 2nd and blasting past me, then slowing down and doing it over and over again tryin to make me run. i just laughed and went nooooooooooooooo way man.
ntimd8 ran him, he said hes never been chopped so hard hahaha :)
with the blue 180, from where i was which was still a fair bit behind where they finished, marvin was catching on him quickly and flew past him then as soon as he went past the guy in the 180 braked and put his blinkers on..., so i dont know if he let off before or what, but it looked to me like marvin caught him and the end, and just blasted past even tho the guy in the blue 180 thought he won.
marvin what do you launch at with a turbo like that? 6k? :(
you need some sliiiiiiiiiicks.
results were from what i remember.....that silver gtst with the fmic running the blue 180.......180 chopped him hard on launch and then the skyline flew past with mad top end :)
blue rps13 180 and marvin, marvin won.
green lancer gsr, i think its a 2l, **** that was quick and sounded awesome, 1st run the lancer killed marvin, second run the lancer killed him on launch, marvin killed him for the rest :)
silver gsr and marvin, i think the silver gsr got that one, then second run marvin bogged it hard and had some problems so didnt keep going? guess that was when he overheated?
feel free to correct me where im wrong :)
johnny, why do you keep calling him malvin? isnt his name marvin? :)
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88338
hahaha I think malvin is Johnny's special name for me :)
What I meant with FeelDG is I have not seen him run at the runs but then again I don't go to often. I have not heard any stories about it from the runs thats all.
It's good that he likes to give it a hit here and there coz thats what they are built for wish I had of been there coz it would have been fun trying to run him while rolling. See how my little beast measures up with it's big brother.
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88384
Yeah guys I've had enough and I'm going to go and get some practice before I show my face again... jk guys :)
George I think you have a good idea there with all of us going out when the new track is open. I will be up for that coz I would have more time to set the car right.
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88605
Guys,
Without sounding like and old fuddy duddy, I think the content of this thread is a bit obvious and not in the spirit of our club/forums. Please remember that this is a _public_ forum - Anyone can read/view.
So I encourage you to go back and edit your posts , maybe re-word a few more approriately, if you catch my drift.
Thank you.
https://www.sau.com.au/forums/topic/5818-hey-jnr-032/#findComment-88668
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
