G'Day folks,
I was wondering who will be particpating on this sunday for Drift Banzai Battle as Inark will be cometeing, am i right?
Any exciting cars will be there as i may go there with mate...
Cheers
Grant
i did have a thread somewhere but its disappeared with all the other forums :P
yeah i'll be there in CEF-ZLA
Goj is going of course...
few others.. everyone else is going to the SAU BBQ... if u check the thread below it has a few small vids of a killa R33 that will be there too
hehhe i thought it would :P
oh its got a drift wing :(
that narrow it down more? hahaha
nah on a serious note its got mex performance down the sides in blue
alot of other stickers covering numerous dents n scratches
Hey guys,
it's no surprise, the rest of field will be Silvias...
I'm looking forward to see CEF-ZLA i action, good luck to u Inark, ur car look sweet btw
Cheers
Grant
im dissapointed... i had a surprise planned... i was going to dress it up in full D1 style with full car vynils and decals :) monkeymagic style like the URAS cars cause thats who the kit was... BUT my aunty couldnt get them done in time :( too much work on for her at the moment.
shame... would have looked awesome
this style but in white and chrome....
well for those that didnt come u missed out on a great day at the track...
heres a couple of vids of CEF-ZLA going around the track at the hand of NZD1 driver Jarius during the first heats to get into the top 16... bloody awesome effort considering this was the only time he had ever been in my car
right click and save as - this is Jairus's second pass... first time he was even in the car so he didnt exactly have much time to prac in it to get used to it.
right click and save as - 3rd pass... mmmmmmmm
i dont have enough webspace for high quality... nah just him... he was doing some filming for something... cant remember what... he was robbed of a higher placing if u ask me... he was far better than the qlder in the onevia
Yeah he was doing some fulming for TV Un Zud 4.
It was a killer, after the first run he had with the Onevia it was one "win" each so we re-ran it. Then when he was following the Onevia he did a big fast entry into the last corner at about double the speed of the front car so if he hadn't stop drifting he would have hit the car in front. So unfortunately he lost becasue of that.
But he was one of the three fastest guys on the day with his entry speed. Also he was one of the nicest guys you will meet. Anyway, apart from burnt little patches where I missed with sunscreen on my arms it was good.
Also two drivers were unhappy about decisions, so we will have to find out exactly what happened.
yeah but from what i was told in breifing the onevia should have been imitating him but instead went in a lot hotter cause he wasnt doing that last corner in one motion... so technically he caused that clash himself... but none the less he was damn good (the guy in the onevia) and yeah hes a top bloke Jairus... got a long real well.
he gave me card to keep in touch... im going to check the D1NZ schedule for 2005 and try and head back for a round.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
