I'm just wondering who's out there with a 20 putting out this kind of power. I've seen them every now and again, but it would be nice to have a collection in the same thread.
If you do... post up and let us know your spec list! If you are in the mid 200+rwkw range... go ahead and post up as well. If you have a dyno graph... please post it since it would be nice to see how these mods affect the power band.
No slicks (some 17 inch tyres which cost me 10 bucks each) 2.0 60 foot
Was just a hi flow vg30 turbo (v trim), fmic, gtr fuel pump, and mines map ecu and a bit of boost around 1 bar.
Was dynoed at around 290 but probably had a little more on the night 310-320 rwhp that is
i got 333 HP @ wheels ..
rb20det in a 180sx
hks t04e kit
ems 8860
gtr injectors
bosch 044 fuel pump
etc
havent run it yet , no rego sitting in my garage lol
Sounds good! Nice to see some other S13's with RB's SXC and CS... especially putting out some very respectable power! What's the powerband like with that T04E? I'd be interested to see what cams would do for you...
Not an rb20.. But an rb S13 none the less.
93 S13.
94 rb25 taken out to 2.6lt.
Custom twin turbo set up using 25/30's.
Plus other mods.
best time of 10.8 @ 127mph in the middle of the day in silly heat. Around 600hp @ the wheels on C16.
Pics in my gallery. Shoot me a PM, and I can scan the mag write up when I get time.
Cheers, Josh.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
