Top RB20 Club... do you have over 260rwkw?
Cheers, will do.
Hyperdrive are looking after mine as well, lumpy is the guru
Hey congrats! I take it that was your car in HPI, isnt it already making something like 250rwkws?!?! I cant remember, TD06 with Garret compressor right?
Yes thats the car and turbo, not near those figures yet tho unfortunately...:rofl:
Go's ok running 1bar, is line ball with a mates 12.7sec ute so looking forward to what it can do with proper boost control and some tuning
stand back everyone, looking to crack 300RWKW, not sure how it will go but will soon see how we go. its been built to do it. no specs given out as still got more tweaking to do before engine goes back in.
Well not as impressive as mr boostn32's 300rwkw claim, but the red top rb20 made 301rwhp today at 19psi with a nice tune to look after an aging motor. Many thanks to Hyperdrive who have taken the car from being weak as piss (240rwhp at 20psi) to where its at now.
Do you know what Garret wheel is on the turbo, was it a TD05 or TD06. Love to see a dyno printout with the boost curve:)
Waiting to see the specs of this 300rwkw creation...hurry up ppl and get these setups tuned:)
hi, guys check out this gts4 rb20det in www.skylinesdownunder.com
I've been in the car, but not with power it has now, It has everthing done to it. Its been in one of those performance videos from nz pulling really good 1/4 time.
specs from site.
Make: NISSAN
Year/Model: 90 R32GTS-4 2.0ltr
Engine: PORT POLISED HEAD, CUSTOM EXHAUST MANIFOLD ,LAGE TURBO
Induction: CUSTOM INTAKE AND INTERCOOLER
Exhaust: 3 INCH MANDEL BENT STANLESS REAR MUFFER 5 INCH TIP
Drivetrain: 4WD , GTR BOX,4 PUK KEVLAR CERMIC CLUTCH
Body styling: FULL AFTER MARKET KIT VEILSIDE WING
Wheels & Rubber: 18 INCH CHROME ANTERAS WIT 265/35/18 DUNLOPS
R/W kW: 318kw@20psi
Quarter mile time: 11.703@116mph
im running 250lb in my rear with some reasonable bilistein shocks. Not too bad, but i would love to try the 500lb's i have sitting in my room  :D
Harder springs = less traction:cheers:
specs from site.
Make: NISSAN
R/W kW: 318kw@20psi
11.7 and 116 mph = ~250 rwkw (that's on a roller dyno)
If it is a hub dyno, add 15 rwkw (no wheels or rollers).
265 rhkw (rear hub kilowatts)
Note no mention of camshafts:cheers:
I have 200lb springs in the rear of mine, with good even tyre ware, and really not a lot of squat. Id be looking at the shock setting.
Sydneykid, you stated harder springs equalling less traction. This statement I can understand with a live rear end but with the primitive design ( compared to later models ) of the HR31 IRS, soft springs, especially the standard gear send the rear into enomous negative camber lifting a lot of the rubber off the road.
Many owners have reported success in better traction and faster 1/4 mile times when going to harder rear suspension.
Harder springs = Less Squat = More than 1/3 the tyre touching the ground
Its a fine line with a HR31 IRS... too soft, and you squat so much that i've had 1/3 the tyre only touching the ground from footage... and thats hardly gonna help the problem.
Since i've installed slightly harder bilisteing shocks (over the ones i had) its been noticeably better, not startling... but much better
Just some axle tramp to sort out now
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
