Yes thats the car and turbo, not near those figures yet tho unfortunately...:rofl:
Go's ok running 1bar, is line ball with a mates 12.7sec ute so looking forward to what it can do with proper boost control and some tuning
Well not as impressive as mr boostn32's 300rwkw claim, but the red top rb20 made 301rwhp today at 19psi with a nice tune to look after an aging motor. Many thanks to Hyperdrive who have taken the car from being weak as piss (240rwhp at 20psi) to where its at now.
hi, guys check out this gts4 rb20det in www.skylinesdownunder.com
I've been in the car, but not with power it has now, It has everthing done to it. Its been in one of those performance videos from nz pulling really good 1/4 time.
specs from site.
Make: NISSAN
Year/Model: 90 R32GTS-4 2.0ltr
Engine: PORT POLISED HEAD, CUSTOM EXHAUST MANIFOLD ,LAGE TURBO
Induction: CUSTOM INTAKE AND INTERCOOLER
Exhaust: 3 INCH MANDEL BENT STANLESS REAR MUFFER 5 INCH TIP
Drivetrain: 4WD , GTR BOX,4 PUK KEVLAR CERMIC CLUTCH
Body styling: FULL AFTER MARKET KIT VEILSIDE WING
Wheels & Rubber: 18 INCH CHROME ANTERAS WIT 265/35/18 DUNLOPS
R/W kW: 318kw@20psi
Quarter mile time: 11.703@116mph
im running 250lb in my rear with some reasonable bilistein shocks. Not too bad, but i would love to try the 500lb's i have sitting in my room  :D
Harder springs = less traction:cheers:
specs from site.
Make: NISSAN
R/W kW: 318kw@20psi
11.7 and 116 mph = ~250 rwkw (that's on a roller dyno)
If it is a hub dyno, add 15 rwkw (no wheels or rollers).
265 rhkw (rear hub kilowatts)
Note no mention of camshafts:cheers:
I have 200lb springs in the rear of mine, with good even tyre ware, and really not a lot of squat. Id be looking at the shock setting.
Sydneykid, you stated harder springs equalling less traction. This statement I can understand with a live rear end but with the primitive design ( compared to later models ) of the HR31 IRS, soft springs, especially the standard gear send the rear into enomous negative camber lifting a lot of the rubber off the road.
Many owners have reported success in better traction and faster 1/4 mile times when going to harder rear suspension.
Harder springs = Less Squat = More than 1/3 the tyre touching the ground
Its a fine line with a HR31 IRS... too soft, and you squat so much that i've had 1/3 the tyre only touching the ground from footage... and thats hardly gonna help the problem.
Since i've installed slightly harder bilisteing shocks (over the ones i had) its been noticeably better, not startling... but much better
Just some axle tramp to sort out now
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
