11.7 and 116 mph = ~250 rwkw (that's on a roller dyno)
If it is a hub dyno, add 15 rwkw (no wheels or rollers).
265 rhkw (rear hub kilowatts)
Note no mention of camshafts:cheers:
So what sort of camshaft/timing do you think this engine setup has. I would be surprised if this is radical, may be just an improved standard setup
Turbine
sk, the hr31 irs is very difficult to control. No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground. Every import 31 has this problem.
Took it for a proper drive for the first time since I got the car back from the tune, and its developed a nasty missfire as soon as it hits boost. Im thinking ignition (again) since the back of the car was covered in fuel when I got back... time to bring the plug gap down yet again.
sk, the hr31 irs is very difficult to control.  No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground.  Every import 31 has this problem..
This one works great;
They are no more difficult than any IRS with struts. The trick is to find out exactly how much it is going to squat, I use a video camera and cable ties on the shock shafts for that. Once you know, then you can simulate it on the wheel aligner by jacking it up and down with the rear springs out. You remove as much dynamic camber change as you can with the offsett bushes. Then you set the static camber so that the tyre contact patch is optimised at full squat. It's pretty simple really.:(
we aint all on race team budgets remember :P
You're kidding, right? Our budget wouldn't buy the paint job on an Autosalon car. It's not about how much you spend, but what you spend it on. An example;
Hey mate, for $700 I can get you lots more power, enough to improve your 1/4 times by 0.5 sec. How fast would you jump? :wassup:
Compared to;
Hey mate, for $700 I can do a wheel alignment that will improve your 1/4 times by 0.5 sec. Now how fast would you jump? :kick:
We have to make that sort of decision all the time, what do we spend the limited money on to get the best result. Engine power bragging rights are pretty worthless, it's all about how long it takes to get from the start of the race to the end of the race.
:cheers:
Hi all , have to agree some mods forced by limited budgets can be very effective . Some time back I had DR30 IRS grafted into a Bluebird and remember thinking the crossmember bushes were too soft . The budget fix was to drop the rear end out and fill the gaps in the rubber bushes with of all things stickerflex . This stuff has very similar consistency to the rubber and is the cheap way to get a "works" style bush that still has some compliance . I have seen a few HR31 IRS rear ends and their X member bushes are REALLY soft . This will not help with tramp or alignments .
I got the car back today and it did 271rwhp@16psi .It was'nt tuned in kill mode but it's safe.I used to get like 90 knock all the time with the old tune but now the most is 35 and thats raping it.300 would be good to have so I'll see what happens.
Nice, it wil make 300 easily with 19-20psi:). How does it feel on the road?
Can you post up a link to your dyno sheet (and mine.. I lost the link), be interesting to see how much better your power curve looks.
HKS GT2535 turbo
Stainless exhaust manifold
R32 GTR intercooler
Z32 afm
Apexi pod
R33 GTR injectors
Greddy profec b boost controller
3inch dump pipe,3inch mild steel mandral bent exhaust
Bosch 040 fuel pump
Nismo adjustable fuel regulator
Apexi PFC
16psi
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
