Well just picked up from the latest tune getting there but not yet still getting hot at the moment guess i need to get that new radiator and still recons exhaust is restrictive but I like it the way it is so this is gonna have to do for now still its not to bad check out the graphs and opions welcome .Graphs show both high and low boost
Cheers Peter
lol.
I came across one of 'those' people the other day at Sprint Autoparts.
He was dribbling on how he had this R32 GTS-T.
166rwkw on 12.5psi, malpassi fuel reg, std ecu, exhaust, fmic.
He said he ran a 12.8 at 110mph with a 60ft of ~2.2. lol
He said if he got the launch sorted he would be close to the 11's. HAHAHA
What a knob head. Seriously, so full of him self.
ADPSI, which holds the current highest out put for an rb20 in aus, will be back out on the road soon, with even more power now. Its made 500+rwhp previously.
My 20 cents worth, it's not an RB20 if it has an RB26 crank, 3.5mm oversize pistons and RB26 rods. That's an RB24:cheers:
Legend01  besides shim clearances did you have any problems ?  no spring binding etc
i have a pair ready to roll
cheers
Hi MrMayhem
Being hydrolic there was no problem with shim clearences had the head done port and polish new standard valve springs and the cams just bolted straight in no problems with clearences with the lobs touching the head all lobs cleared fine though i must state that the hks cams 264 duration 9.0mm lift im using are heal and toe which means the take a little of the heal of the cam and add a little to the toe to get the lift required and had no trouble that im aware of with valve springs binding but only been reving it to 7500 rpm
Cheers Peter
Hi MrMayhem
                                                          Cheers Peter
Gday peter - spring binding doesnt depend on RPM - if springs dont biond when you spin then engine over by hand, it wont bing at 9k rpm
cheers,
Matt
got my car dynoed today
190.7rwkw @14psi
has run 13.6 on 12psi 102.4mph
have had a max of 104mph
next mods:
suspension
ex cam gear
chip ecu
im not aiming at any great figures, instead a great road car with plenty of response.
RB20 forever!
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
