Top RB20 Club... do you have over 260rwkw?
Well just picked up from the latest tune getting there but not yet still getting hot at the moment guess i need to get that new radiator and still recons exhaust is restrictive but I like it the way it is so this is gonna have to do for now still its not to bad check out the graphs and opions welcome .Graphs show both high and low boost
Cheers Peter
ADPSI, which holds the current highest out put for an rb20 in aus, will be back out on the road soon, with even more power now. Its made 500+rwhp previously.
nice a 500rwhp RB20, would love to know the specs
lol.
I came across one of 'those' people the other day at Sprint Autoparts.
He was dribbling on how he had this R32 GTS-T.
166rwkw on 12.5psi, malpassi fuel reg, std ecu, exhaust, fmic.
He said he ran a 12.8 at 110mph with a 60ft of ~2.2. lol
He said if he got the launch sorted he would be close to the 11's. HAHAHA
What a knob head. Seriously, so full of him self.
My 20 cents worth, it's not an RB20 if it has an RB26 crank, 3.5mm oversize pistons and RB26 rods. That's an RB24:cheers:
lol.
IHe said he ran a 12.8 at 110mph with a 60ft of ~2.2. lol
He said he ran a 10.xx with slicks and once he hit NOS 9.xx.
.... on Gran Turismo 4
Legend01  besides shim clearances did you have any problems ?  no spring binding etc
i have a pair ready to roll
cheers
Hi MrMayhem
Being hydrolic there was no problem with shim clearences had the head done port and polish new standard valve springs and the cams just bolted straight in no problems with clearences with the lobs touching the head all lobs cleared fine though i must state that the hks cams 264 duration 9.0mm lift im using are heal and toe which means the take a little of the heal of the cam and add a little to the toe to get the lift required and had no trouble that im aware of with valve springs binding but only been reving it to 7500 rpm
Cheers Peter
Hi MrMayhem
                                                          Cheers Peter
Gday peter - spring binding doesnt depend on RPM - if springs dont biond when you spin then engine over by hand, it wont bing at 9k rpm
cheers,
Matt
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
