Top RB20 Club... do you have over 260rwkw?
Very interested to see the plot. Same tuner and dyno...about the same power at the same boost...will be interesting to see the difference is repsonse...im guessing yours must come on a little soon then mine.
You must be stoked...car is a completely different animal once you get some boost in them
Hi Guys,
Got my car back with results.
GT3071
Apexi PFC
Apexi FMIC
full exhaust
cold air intake and shield
GTR injectors
040 fuel pump
254.6 RWKW on 22psi
all on standard internals, so hoping it lasts a little while at least as it is heaps of fun..
lots of boost you are running there........
def want to see a dyno sheet.
2.5K for machining? I take it that involved head work etc, or at least shaping the combustion chamber for oversized pistons, or clearing the block for a crank with a longer throw.
That dyno plot suggests to me that thing would be a great setup with a smaller exhaust housing. You are running a 0.87 , correct?
Whats the next commonly available housing size down, is there a 0.73 etc. Someone told me the 3071 runs a pretty big turbine, so dont be too scared of going down a size in housings. Also what manifold are you running, and what sized gate?
Running.64 housing. Turbo is low mount version, sitting on standard manifold. The gate is the crappy one with turbo.
Cannot control the boost to be any lower then 22psi. (any suggestions)
3071 is a big turbine wheel - seems good so far other then boost issue.
How does it compare to your graph Roy - as this turbo was a gamble against your great set up.
thats for porting, cc'd chamber, 3 angle valve job, new guides, seals.
drill bearings, chem/acid wash block, boring, honing, decking, beam polishing rods, and other stuff. it looks like my TD06-20G will be to small, so turbo and manifold may be for sale soon.
Hi Guys,
GT3071
Apexi PFC
Apexi FMIC
full exhaust
GTR injectors
040 fuel pump
254.6 RWKW on 22psi
I'd look into some cams... guy here stateside just put down 386 rwhp (~288rwkw) on a 30R with similar mods plus cams, gears, and intake mani... I would imagine that power level is attainable with the 3071 as well. What RPM is that where you are hitting 15psi? With full exhaust... do you have a converter in there too?
Nice setup by the way!
Edited by RBsileighty
Max power at 8250rpm!! Holy crap, my 20 has never seen anywhere near that in two years.
Max power is made at just over 6,000rpm on mine and rev limiter is set to 7,000rpm.
If you are making peak power at 8250rpm where did you set your rev limit to?
8250rpm holy crap was my first thought also.. Not going there very often but seems to happily scream all the way there. Rev limiter not sure about.. Running full titanium 3 1/4 inch from turbo with high flow cat.
getting 1 bar at 4200 RPM so it's pretty good.
If I could afford cams I prob would, but having fun trying not to skid in the dry at high RPM on 255's.
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
