its internally gated...and i dont have injectors yet, but thats next on my list. the guys who r doing for me (race solutions and hitman in penrith) asked me the same question bout injectors, and after i told them i havnt done them yet they said theyll see how far they can push the stockies....im hoping to get injectors done after christmas :(
Without injectors done forget about joing the "260kw" club. And if its a TO4 with internal gate have you got a pic of it?
When you said turbo rebuilt to TO4 specs did you mean your stock turbo supposedly built to TO4 specs or another turbo that you have purchased?
oh and im not expecting to get above the 260 mark without getting other stuff done, meaning mainly injectors (which is my next project) and a fuel regulator...i was simply stating what i have gotten done thus far, so please dont treat me like an idiot...as im not one, with what i have done so far, im realistically hoping for 220-230 atw kw, just thought id make that clear...thanks
Edited by R32_GTS-4
so is 220-230 theoretically possible with standard injectors?
no, stockers rated at 270cc's are crap for 240 HP at the wheels, they will be maxed out at that power.
100% duty cycle is not your friend, you should never run over 80% for safteys sake.
hell, im taking out my 550's and going to 720's just to have a low duty cycle, and thats with about 450bhp.......
Mine were hitting 92% duty for 176rwkw. Keep reving it past peak power and it required 100% duty to hold a 12:1 AFR.
They were slightly dirty as cold starts would see it stumble slightly.
Depends how happy the dyno is if you make 220kw with std injectors.
All though at the dyno day there was an R32 running stock ecu, stock airboox, exhaust, fmic, HKS GT2530 @ 1bar. That made 178rwkw.
Unsure if injectors were at their maximum, it now requires an FCD to make more power.
Edited by Cubes
maybe past 240hp at the wheels. Thats where I'm at with the stock Rb20 injectors @ 14psi with the stock turbo.
That dyno is either very happy, the injectors aren't really standard or the fuel pressure is way above standard. There are no miracles in engines, including fuel injectors.
:angry: cheers :P
:) cheers :)
Well not a happy dyno but I do have a 255lph fuel pump blowing past the stock regulator :)
I recently had my GTR injectors flowed.
Base fuel pressure set was 40psi.
@ 100% duty they flowed 474-480cc
@ 80% duty they flowed 384-390cc.
So theoretically, say the GTST injectors are 270cc's.
270cc's * 0.8 = 216cc (80% duty).
Isn't the old rule of injectors 1 cc per hp. 216hp.
Or is that 1cc per hp based on 100% duty flow i.e 270cc @ 100% duty makes 270hp at 80%duty.
Kind of messy but hope it makes sense. :)
Stock RB20DET running 14psi with a tuned ecu (PFC) on the dyno's I run on generally make spot on 170rwkw.
Edited by Cubes
Hi R32_gts-4
550cc will get you the rwkw your after Matt tuned mine with 550 and there still on standard presure and im running 238rwkw on his dyno with other mods to though but if your running a to4 as i was i think u might be battling i had mine rebuilt twice and it still dont flow enough runs outa puff at 6800rpm and its rated at 500hp
Cheers Peter
Edited by legend01
hey thanks for the info guys...i have another question, does anyone know the part number for bosch 550 injectors, i called their inquiry line and they have no idea, great help they were haha
also does anything need to be modifyed to fit bigger flowing injectors? i heard somewhere that u need a higher impedance, i think? is this right, or am i getting told crap??
thanks
thanks
hey dude, I have a set of Nismo 555cc injectors in my GTS4, they are straight fit just plug in and go. Don't worry about some obscure help line, just go to a site sponsor or nengun (where i got mine) and get them cheap and the best quality around.
I've had my 555s for 3 years now and once tuned on a RB20 like you then idle and economy is perfect. Can't go wrong! :)
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
