Interloper Posted November 3, 2005 Share Posted November 3, 2005 thanks for the info mate...how much dosh would they set me back?where do i get them from? <{POST_SNAPBACK}> as i said in the above post, nengun or any site sponsor or even site sponsors at ns.com as they have some really good deals sometimes. Mine cost me $1050 3 years ago delivered and that was when the exchange rate sucked. now a set of 6 should cost no more than $900 delivered. Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1688116 Share on other sites More sharing options...
Cubes Posted November 3, 2005 Share Posted November 3, 2005 Keep an eye out for R33 GTR N1 injectors, they too are 555cc's. I've only ever seen 2 sets for sale. Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1688617 Share on other sites More sharing options...
Interloper Posted November 4, 2005 Share Posted November 4, 2005 check out these prices as an example: http://www.nissansilvia.com/forums/index.php?showtopic=83093 could be even cheaper if you look around Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1689635 Share on other sites More sharing options...
SimonR32 Posted November 4, 2005 Share Posted November 4, 2005 tommorrow is pop or power will post graph asap Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1691036 Share on other sites More sharing options...
R32_GTS-4 Posted November 5, 2005 Share Posted November 5, 2005 if i get high impedance injectors...do i need to use a resistor pack? (i think thats what its called?) Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1691927 Share on other sites More sharing options...
RB power Posted November 5, 2005 Share Posted November 5, 2005 nope Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692001 Share on other sites More sharing options...
Interloper Posted November 5, 2005 Share Posted November 5, 2005 no, because the stock injectors are high impedence. so its a straight fit. if i get high impedance injectors...do i need to use a resistor pack? (i think thats what its called?) <{POST_SNAPBACK}> Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692241 Share on other sites More sharing options...
R32_GTS-4 Posted November 5, 2005 Share Posted November 5, 2005 (edited) thanks interloper...i went to that nengun performance webpage and found some sard 550cc injectors to my door for $690, can anyone tell me though...what twin hole spray injectors are? thanks Edited November 5, 2005 by R32_GTS-4 Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692432 Share on other sites More sharing options...
R32_GTS-4 Posted November 5, 2005 Share Posted November 5, 2005 (edited) i also have another question, regaurding power fc, does it remove the speed limiter, boost limiter and rev limiter? would i be better off getting a haltek e11 or a power fc? Edited November 5, 2005 by R32_GTS-4 Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692446 Share on other sites More sharing options...
Interloper Posted November 5, 2005 Share Posted November 5, 2005 i also have another question, regaurding power fc, does it remove the speed limiter, boost limiter and rev limiter? would i be better off getting a haltek e11 or a power fc? <{POST_SNAPBACK}> go the PFC, it does all those functions and more! I would have bought one but i decided to get the stock computer remapped instead Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692792 Share on other sites More sharing options...
Cubes Posted November 6, 2005 Share Posted November 6, 2005 I'm happy with the PFC. It sorted the slight idle hunt and slight occasional high idle I used to suffer with the stock ecu. Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1692876 Share on other sites More sharing options...
R31 POWER Posted November 6, 2005 Share Posted November 6, 2005 Funny you should say that joel as i have high idling and hunting with my pfc and it shits me to tears!the standard ecu was faultless. Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1693824 Share on other sites More sharing options...
Cubes Posted November 6, 2005 Share Posted November 6, 2005 I've found the trick with the pfc is to ensure you set idle with the aac valve solanoid disconnected and set the idle as close to to the pfc set idle rpm. The trick is to get it spot on. Then... init the pfc (also a must as it doesn't seem to relearn as well afterwards) and let it do the 30minute idle thing with a/c off then a/c on. The only time I have a slight elevated idle is occasionally with the a/c on, even then it settles to the usual a/c idle rpm within a few secs. But definitely no hunting.. when I had the motor out I cleaned every single little thing.. throttle body, plenum, aac + the cold start idle control i think thats the ICV or something can't remember exactly. I must admit I can't remember any idle hunting while the motor was being run in on the stock ecu. Maybe it wasn't the pfc.. maybe the cleaning?!? Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1693924 Share on other sites More sharing options...
SimonR32 Posted November 6, 2005 Share Posted November 6, 2005 ok something is wrong with my car atm... so tune didnt go well top end. stopped making power at 5000 can tell you it was making 250rwhp @ 4100 or 112kmph hopefully will all be fixed and tuned by sat Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1694010 Share on other sites More sharing options...
SimonR32 Posted November 11, 2005 Share Posted November 11, 2005 3rd gear finally went bang yesterday, a full year out of it so im not suprised... so no dyno, this car just doesnt wanna do what its told Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1706022 Share on other sites More sharing options...
Roy Posted November 11, 2005 Share Posted November 11, 2005 Oops. Sorry to hear. Out of interest what clutch are you running, kms on the box and what fluid were you running? Also how hard are you on the box, do you clutch the thing mid corner, burnouts, flat changes etc etc??? Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1706367 Share on other sites More sharing options...
Cubes Posted November 11, 2005 Share Posted November 11, 2005 sky30 with his 300rwkw monster has gone through quite a few rb20det box's. BUT it is a 3ltr and its torque that kills gearbox's not power. Third gear is appears to be the one to go.. No hard changes, mid way accelerating through third it goes BANG! Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1706381 Share on other sites More sharing options...
SimonR32 Posted November 11, 2005 Share Posted November 11, 2005 Oops. Sorry to hear. Out of interest what clutch are you running, kms on the box and what fluid were you running?Also how hard are you on the box, do you clutch the thing mid corner, burnouts, flat changes etc etc??? <{POST_SNAPBACK}> 9 puck brass button clutch... box is unknown kms cause of man conversion and i was running redline oil im very hard on the box, i clutch mid corners, i drop 2nd a lot in the dry from standstill... decently fast changes not quiet flat changes but close box held up for a full year of abuse with around 300rwhp but finally gave up on me... im actually quiet impressed that it lasted this long. just popped now cause boost has been raised and intake pipe which was collapsing has been fixed. like the day before it happened so im hoping this isnt too regualr occurance if you speak to R32-Gts (simon) on these forums, he has broken so many rb20 boxes its a joke thinking of getting a spare box cryogenically treated and shot peened, i cant be bothered forking out on a RB25 item Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1706952 Share on other sites More sharing options...
PUS16 Posted November 11, 2005 Share Posted November 11, 2005 yeh dude i know the feeling well!!!! i went through 4 of them! 2 with the 20 and 2 with the 30 then i finally got sick of forking out the cash 4 the shit boxes and bought a 25det one and i gotta sa man i should have done it a long time ago coz it is sooooooooooooo worth it!!!!! Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1707302 Share on other sites More sharing options...
black sky Posted November 14, 2005 Share Posted November 14, 2005 (edited) This is my car and as i'm sure you can guess it's got an rb20det in it just got it back from the tunners the other day and it's got 241.3 rwkw with no real power loss right up to 7500rpm. It made 253.8 rwkw but was runnin a little lean 12.5:1 so we tuned it back to a safe point . i know it's not really 260rwkw but hey it's got 322rwhp so i thought i'd post it up. By the way roy can you give me the formula to convert speed to rpm Cheers anthony Edited November 14, 2005 by black sky Link to comment https://www.sau.com.au/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page/40/#findComment-1712175 Share on other sites More sharing options...
