OK its been a long time since i made a post, but just an update, i have all my engine parts back from the machine shop and im still aiming to crack 300rwkw. it may seen like a big ask but i know it is possible.
I do have to say to all that want near 280 - 300rwkw it is not cheap at all. but it is very interesting in trying to make good power out of the RB20. Sure i could of gone a RB25 or one of the other combos and it would of been a lot easier but that wouldnt be a challange.
It seems like im almost there with the build and then i need to spend more money. Its taken a while but im about 2 weeks away from the first start up of my new engine. and then its only a matter of running the engine in and then seeing what it can do.
Edited by boostn32
So whats your cold starts like with the fcon silver gts-t? mine has very doughy throttle response until its atleast had a couple minutes to warm up.
actually start up is perfect..
when i turn the car off it has a habit of running for 2secs then shutting down after the keys are out sometimes..
also it needs more revs in lower gears, used to be able to slow down to 1200rpm in second and just press the accelerator, now if i do it i get a bunny hop effect.. and in 1st its the same under 1500rpm
Yeh BD4s use one of those thingie type dynos too. They were saying it reads a bit higher then that other type of dyno thingie that most places use...i really dont know what im talking about:)
yeh the dyno is a different type, they really spare no expense with their facilities..
I have the same problem too.
Do you have bigger injectors? I was told that it could be because at low duty cycles/rpm they open too much casuing a hop/jerking effect.
Cheers.
Cheers.
Shouldnt be at all related to injectors if its tuned correctly
The car should be like factory.
Mine was with 740's
not an rb20 but i've been driving my mates sr20 silvia with hks gt2835r, he has 750cc injectors with a pfc tuned by lumpy,
runs and idles and drives perfectly on and off boost at any revs
think that would be cause of the power fc?
so tempting to gank his turbo haha but still need an ecu for the old redtop
ahh well i'll get there one day
Awesome Boostn32, care to share the specs? :(
I will share specs once the power level is reached, i will say it has Arias forgies, HKS cams undisclosed specs, microtech, 700cc injectors, custom plenum, atm it will have a trust TD06 turbo kit but will be upgraded.
are you using standard rods?
you setup sounds simmilar to what ive got going right now.....results will be interesting.
Hey guys..just thought my effort was worth posting...
93 R32 GTS-t using completely STOCK (un-chipped) computer and stock auto transmission i got 208.1 RWKW at 1.4 BAR
other mods are
Cat back 3" zorst
front mount incooler
os gieken adj cam gear (exh only)
Arias Forged pistons 20thou ovesize
ported and polished heads
1mm oversize valves
match ported manifolds
ported exhaust manifold
high flowed VG30 Turbo
Sard Adj Fuel Reg
Fully balanced bottom end
AVCR boost ctrl
k&n flat panel filter
standard injectors
GTR Fuel pump
so after a manual conversion some injectors and a power FC should maybe hit around the 260 RWKW...
i am surprised at the stock computer getting this far..well done NISSAN !!
I had mine dynoed again on Dr Drifts brand new dyno on friday night....
208.8rwkw at 16.5psi.
However, the stock actuator on the R34 GTT highflow turbo is only rated at 7pounds (i think) so it can't hold boost properly and it spikes badly to almost 19psi. On cold days (low ambient temps) it spikes even worse so i'm looking at changing to a HKS GTRS pretty soon. or as soon as funds allow.
Mods are the usual:
Z32 airflow meter
Nismo 555cc injectors
Full 3" exhaust
K&N pod
Dr Drift remapped stock ecu
HKS type S intercooler
R34 GTT highflow
Bosch 040 fuel pump
I think thats it.....
any comments? :mellow:
you want my advice??
ditch the dr drift ecu..
get a pfc
gain 10rwkw
how much have you spent on tuning with sam? and the chip itself?
i spent over $700 hours and hours altogether and all i had was a badly tuned car with a start up problem, an idle problem and detonation, he kept insisting it wasnt the sofware but the AFM, i plugged in the HKS fcon and probelm seemed to disappear??
now sam is an ok guy, never stated that he wouldnt fix it, but im in sydney and i couldnt wait for him to come back and forth..
in conclusion if your in melb maybe it aint so bad, but anywhere else dont bother!
not worth saving a few $$ get it done right the first time! not just a remapp that plays with timing and fuel etc
i paid almost $700 on tuning the Fcon alone and would gladly pay it again rarther than $300 on tuning the remap
Mods are the usual:
Z32 airflow meter
Full 3" exhaust
K&N pod
R34 GTT highflow
Bosch 040 fuel pump
get a pfc
gain 10rwkw
thanks for your ideas.
I didn't go the pfc as i was hoping that it would be cheaper to get it remapped - this was more than a year ago.
I do have a few problems with the tune but Sam says he will fix them with out any extra cost, so i don't have a problem with that.
If i was to get a PFC now it would obviously be like paying twice for the same thing, so i will stick with the remap.
He's got new laptop tuning software now, so he says it far easier to tune than before, he's promised to have another look to see if theres any improvements to be had.
I don't think a PFC can gain more power than a remap, its all in the tune and my a/f ratios are at a level i consider safe. There's nothing wrong with remaps themselves - just think of the Mines jap ecu's.
Cheers. :mellow:
mine's arnt the best example of a remap, and sam used his new software on my car.. no one could figure out the probelm, not even the software designer..
its up to you what you do in the end how much u can afford etc,,
if you managed to get a year out of the remap then cut your loses...
really!!!!!!!!!!!1 think about it! also remember that even if you get a pfc, ap engineering fc are in demand and a second hand one you could always sell easily in the end
u tried turning the boost down??
the graph looks mega rich!
and i dont thing a pfc will give u that much
look for about 230ish
post-8646-1139292736.jpgHey guys..just thought my effort was worth posting...
other mods are
Cat back 3" zorst
1mm oversize valves
Sard Adj Fuel Reg
AVCR boost ctrl
standard injectors
GTR Fuel pump
edit: added ur graph
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
