Max power on mine is made at around 6,000rpm and rev limiter is set at 7,000rpm. Power doesnt dive it just slowly tapers down.
I agree with Roy about wringing the first two gears a bit more but my car is all over the shop in first and second and I always am bouncing off the limiter unintentionally.
I need to improve my driving skills/suspension/tyres before I will bump it higher.
post-7066-1142056038.jpgOk after a long wait car is finally up and running again although still with restriction issues will post the graph and maybe get a bit of a disscussion going on possible causes tuner is still leaning towards exhaust as it is pretty quiet the other is inlet track somewhere anyway u will see by the power curve that there is a problem I just gotta find the damn thing
cheers Peter
Edited by legend01
Thought about doing trhat but it wouldn't have told me anything as anyone that drops there exhaust will make more power wheather the exhaust was restrictive or not but thanks for the suggestion
Peter
Peter
I wouldn't be complaining with that power level anyway. :/
Can you remind us what kind of turbo you have and bottom end?
Those are some mighty high intake temps! where do they stick the sensor?
It will make more power without the exhaust as any car will any exhaust is a restriction we did try this and it made a heap more power but that was when I was maken 238rwkw since the engine will flow exhaust gases faster with no exhaust air into and out the engine it not pinpointing where the flow hold up is but i think a newer exhaust has to be the first step as the intake side of things is suppose to be good for 450 hp well thats how it was explained to me
Interlooper the bottom end is stock engine has only done around the 65000ks mark as ive had the haed of for porting bores looked brand new so it was left alone turbo is a garrett GT3040R
update
from information gained it appears 3" exhaust will not flow fast enough above 250rwkw so just bought a 3.5" cat back exhaust will fit that and then try tuning again c if that fixes the problem
Cheers Peter
Edited by legend01
update
Cheers Peter
what brand exhaust did you buy? or is it a custom one?
ok the engine is nearly done, it might be in on saturday morning, i have come accross a problem, i have one washer left over, i think its from the bottom end, its a silver washer with a tapered edge, its about 15mm across.
anyone got an idea where its from.
well its nearly all done, just a few more bits, this is the engine that i hope to crack 300RWKW+ with. will it happen, u bet it will. its taken so long and its only a week or so away from dyno run in and full power tune.
well here it is, the engine ive been building, this is the one i hope to crack 300RWKW+ with, its been so long and now its only a week or so away from the dyno run in and full power tune.
Edited by boostn32
Yo everyone, just wondering if any of the RB20 owners with over 240rwkw have had engine failures or mechanical troubles when used in a circuit/drift enviroment? reason i ask is my rb20 just made 258rwkw @18psi (mods are listed here:) http://www.skylinesaustralia.com/forums/in...ic=103095&st=20 but the tuner recommended i only run with around 1 bar not because the tune wasnt safe, (it was detonation free at 18psi) but because the sheer mechanical strength of the motor could not take that sort of power continuously ie lots of revlimiter action in drift. Any opinions would be greatly appreciated, especially from roy & other RB20 heros who use there cars in circiut or drift where are they are given a pounding.
Cheers.
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
