my old 32 made 232rwkw stock engine
hks 2530, fcd, cooler, pump, exhaust
the power your after is nothing for a standard internal rb20 most of the guys in this thread a still on stock internals
i've got a very similar setup but am only running around 190rwkw. how much boost did u run to achieve 232rwkw?
Some of you guys have done mods but dont list them all... have any of you guys done over-sized pistons?
...We both agree you need bigger injectors, cams, cam gears and a larger turbo coupled with some form of a standalone or ECU management. The only thing we differ on is that he says I will need over-sized pistons... if not, then I'll need a new block soon after due to the limitations of the stock block. But I dont see anyone doing this.
I am planning to get 300rwhp or 223.88rwkw. It's not quite up with you guys in this thread... but decently good. The following are the mods I have:
RB20DET
Plazmaman intake
stainless steel high mount exhaust mani
t3/t4 (sorry... I bought it and it just came into the shop.. forgot the trim size and all... but power is well enough for 300)
555cc Tomei injectors
JGY Customs RB20DET fuel rail
Sard Type R fuel regulator
Tomei cam gears (256/8.5mm)
Cam gears
HKS SSQV
FMIC
Exhaust (2.5in from turbo the goes to 3in when there's space... right below driver/passenger), no cat
Splitfire coilpacks
GReddy Emanage Ult. using Map sensor
The question is, will I need over-sized pistons? I know location and environment plays a large factor, but theoretically, will I be able to achieve my goal? I'll be posting up my results here in the next couple of months.
For that level of power i think you are perhaps over investing in the engine. Sure, it never hurts to cover as many bases as possible, but for that sort of power the completely std RB20 will walk it in with a decent tune and fuel pump etc
Guys like Legend01, myself, AD4M etc all run completely std motors, though Legend01 had some baby cams with his GT30R. (he now has a stroker RB22, but the engine outlasted the car :ninja: ) The std Rb20 will handle that sort of power without worrying about oversized pistons.
Understand that the pistons will add a few cc of displacement and give you the opportunity to play with compression ratios...so all good things, but worth the expense of stripping down the motor, machining, new head gasket, mod combustion chmabers to suit new larger bore etc etc. Then to only run a small turbo that makes 225rwkws odd. You may as well strap on something like a 2835, 3071R and run 22psi all day everyway and make way more power with the comfort of knowing you have pistons.
I would also quastion how much you get out of the cams on a motor that is making 225rwkws odd. They could work very well, but the std cams have been shown to make good numbers as well. Look at the cam specs of the RB26 and then consider how much smaller the RB20 is and you realise the cams in them arent exactly small to start with.
Also the stock block? I think you will find that using uranium as an octanbe booster and a kpw yield detonator may hurt the turbones of your turbo, perhaps might need higher rate valve springs...but the block will be ok. The things are bvery solid, perhaps the most solid of all RB blocks. The fact they dont make as much power as their larger RB brothers means you will rarely see an RB20 block failure. Of course a rod through the side of the block isnt a sign of a weak block. :rofl: But seriously, you will reach the limits of injectors, rods, pistons etc before blocks start to crack on you.
yeah, i'm surprised that they didn't even include 1 pic of your ugly mug :(
But plently of pics of the 32 and a pretty big story spanning 5 pages - ya gotta be happy with that :O
you're famous! :D
Im stoked...and no my co-driver is famous and an absolute champ for hooking it all up. Truth is i did fark all and not very deserving of the article...but i loved the coverage of the car, and i intentionally hid from the cameras...you are right about ugly mugs :P
That'd be rite, hit one pole a people never let you forget it .Roy is right alot of money spent without a need I made 230rwkw with just an old style to4 so have a check through the rb20 dyno thread there's a lot of intresting info there for the power level you are wanting
well I wont be able to post here for much longer as I just bought a gtr so Im putting the gtst back to stock to sell and my 300rwkw engine might be up for sale soon or i might keep it and put it in the gtr :-)
Cheers Peter
Got your tube to Interloper...baby steps. Will tack it up using my car then trial fit it to yours :no:
cool, i've got my gtst back from centerline so whenever your ready PM me & we'll set a date :wub:
<SNIP>I just bought a gtr so Im putting the gtst back to stock to sell and my 300rwkw engine might be up for sale soon or i might keep it and put it in the gtr :-)
Cheers Peter
I would pay to see that!! :wub::no:
What do you reckon, ROY?
PS May have those cam specs but book in the GTS4 - will try to get it and check soon.
roy dont know the duration but the lift is 8.2mm...measured mine last time i had the covers off...i would say the duration would be around 250 degree...
So are you saying you have an RB20DET-R. ie the version of the RB20 that Nissan homolgated to go Grp A Touring Car racing? Or is yours just a straight up RB20DET?
I understand the std RB30DET has 240° inlet and exhaust with 7.8mm lift. Rb26 run about 8.2mm lift on their exhausts, cant remember the fronts?
i bought the VL with the motor in it off my mate, the inlet manifold had the rb20det-r badge on it n the turbo on it was a fair size not the normal rb20 one, looked like a t4 i measured the cams to see what was in it n i got 8.2mm lift, n theres no markings on them to tell if there aftermarket
it didnt have the tubular stainless manifold tho just a normal 20/25 cast item so i dunno it could be just from a gts-x
inlet on the gtr is 8.5mm lift i think
rb20 red top has 248 degree 7.8mm lift, silvertop is 240 degree 7.8mm lift
The DET-R badge is pretty cheap to get of Yahoo or other suppliers.
Not saying what you have isnt real or anything like that, but its unknown so it could be anything.
For a definitive answer it would need to come from a GTS-R, with the DET-R IMO.
And there is very limited cars in the country. About 8.
got my braided line and return line made up this morning, weld up my cooler piping an exhaust this weekend should be struggling to idle by end of next week in ready for a full tune. hoping for about 300hp for now will see wat she puts out tho. getting butterflies in my stomach 6 months and shes nearly driveable
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
http://www.jdm-option.com/feature/06_10/bu...giri80s_03.html
or this why would he swap in Tomei cams if there big from the factory
Edited by 1400r
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
